What's everyoens AFR
Old Jul 23, 2007 | 03:29 PM
boostnss's Avatar
i just got my widband installed 5th grear at 70mph in 14.4-15.2 and wot it's 11.2-12.0.
Old Jul 23, 2007 | 03:36 PM
CTCOBALTSSS's Avatar
Well when it's hot out my AFR is like 10.2 (super rich)
When it's nice and cool out I see 11.2-11.5ish
5th gear @ 70 is the same 14.4-15.2
Old Jul 23, 2007 | 03:39 PM
tum_tum's Avatar
hey he should worry bout leanin out with that 2.79 on stage 2 and his duty cycle is off the hook too
Old Jul 23, 2007 | 04:18 PM
Area47's Avatar
Rent me! per hour
if you're seeing 12.0 at 6500 and above, which you are with the 2.79. your injectors are going static. this is bad.
my a/f is 11.4 all the way up.
2.8 and 42's
i have the magic touch
Old Jul 23, 2007 | 07:05 PM
lsjwannabe's Avatar
11.1 til 5k then from 5k to 7k 10.0 (safe tune)
Old Jul 23, 2007 | 08:20 PM
Kennyspec's Avatar
i dont know if id call 10.0 from 5k to 7k "safe" id call it "dangerously rich"
Old Jul 23, 2007 | 08:29 PM
06blackg85ss's Avatar
yeah 10.0:1 is bad for EGT's
I run 11.4 all the way to 7400 with my 2.55 setup.
Old Jul 23, 2007 | 08:50 PM
Maxim_X's Avatar
Mid-low 11's @wot
Old Jul 23, 2007 | 10:16 PM
95cam86roc's Avatar
The first week of August i will be installing stage II w/a 2.9" pulley. I live in ohio n was wondering what kind of A/F ratio numbers i should expect to see. I dont want to go boom since this is my daily driver. lol
Old Jul 23, 2007 | 10:21 PM
Doc's Avatar
Doc
~12.3
Old Jul 23, 2007 | 10:22 PM
Blown 4-banger's Avatar
I have mine set to start at out at 11.2 (rich for good torque) at 3000-5000, then it leans out to 11.8 from 5000ish-7000 works great for my set up. If only the piece of **** pistons could hold up to it.
Originally Posted by Doc
~12.3
GOT DAYUM!!!!
Last edited by Blown 4-banger; Jul 23, 2007 at 10:22 PM. Reason: Automerged Doublepost
Old Jul 23, 2007 | 10:23 PM
Doc's Avatar
Doc
a little richer under 3500, maybe .5
Red2.4SS/SC's Avatar
12.5
Old Jul 23, 2007 | 10:24 PM
Doc's Avatar
Doc
Originally Posted by Red2.4SS/SC
12.5
you don't count
Old Jul 23, 2007 | 10:26 PM
12.5
Not fair Mr. N/A!!!
Old Jul 23, 2007 | 10:28 PM
lol , i like being n/a , one day ill get a blower ... one day
Old Jul 23, 2007 | 10:30 PM
Doc's Avatar
Doc
hell, try the STS turbo, tbyrne made one with gobs of power...I ran him and he laughed all the way...so far I couldn't read the license plate anymore.
Old Jul 23, 2007 | 10:31 PM
What cam do you have? (specs?)
**** that. Pro charger, who cares if it don't make power at low rpm, its a V8!
Last edited by Blown 4-banger; Jul 23, 2007 at 10:31 PM. Reason: Automerged Doublepost
Old Jul 23, 2007 | 10:40 PM
Doc's Avatar
Doc
true, torque monster if done right
Old Jul 24, 2007 | 06:32 PM
boostnss's Avatar
ok at 10 pst 50% throtle im seeing 14.1 to 15.0 i talked to a performance shop he said that it was fine. i think it's way to lean. And one qustion can you use any tuner to tune your car or just hp?
Old Jul 24, 2007 | 06:38 PM
SilverBalt13's Avatar
When your not in PE mode 14.5-15.0 is fine. When I was running a 2.6 pulley I ran my AFR at 11.5-11.8. With the 2.6 I never felt comfortable going above 11.8.
Old Jul 24, 2007 | 06:42 PM
car won't go into a richer "mode" til A, throttle is past a certain point, or B boost is past 55kpa, or C. rpm is passed. Which would put the motor under a high load, needing the rich condition, at part throttle and cruising speeds that's all the engine needs when not under a high load... the wonders of fuel injection.
Old Jul 24, 2007 | 06:49 PM
boostnss's Avatar
ok so you are saying it's fine if im getting on the hwy at part throttle 10 12 psi and it's at 14.1 to 15.
Old Jul 24, 2007 | 06:50 PM
yup.. I hit 15-16 psi at part throttle at a 14.xx afr and no knock onceI go above 75% throttle... 11.4:1 afr
Old Jul 24, 2007 | 06:51 PM
