Whats your WOT IAT2 TEMPS at?
well, if you want to connect it correctly, from the exit end of endplate it should go into the T then connect to a T with the reservoir and then connect to the input of the pump. I'd first start by hooking the system up to GM specifications to make sure nothing is wrong.
I know i made a mess many times retubing and releasing air to get the coolant pumping, but i just have a lot of cat litter to soak it up and more dex-cool to replace it with
Edit/Update:
I added more coolant. It was half way to the warm fill level of the surge tank. I filled it to the 1/4 hose. It stayed around 100 the entire drive home. I ran full WOT for a mile only managed 140 and it dropped instantly to 120 after I slowed up. I'm hoping it is fixed now.
Turbo Johnny
Feb 21, 2019 09:41 AM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
z28addiction
Sep 28, 2015 12:03 AM
