Wheel Hop
Old Nov 7, 2006 | 06:39 PM
Pauly204's Avatar
Wheel Hop
whats up guys!!? well i have an 06 Coby SS/SC but i dont have the G85 and my car wheel hops soo much i think my engine is gonna end up in the passenger seat...well anywhoo, what are some parts that i can install to stop wheel hop and ... were can i find them? thanks guys!
Old Nov 7, 2006 | 06:43 PM
kyssmySS's Avatar
control arm and tranny mounts from the intense racing website. my buddy has him on his and i cannot get his car to wheel hop no matter what i do. i just ordered them yesterday lol
mkulrey13's Avatar
Click Here also Click Here
an0malous's Avatar
g85 isnt really relavent to wheel hop. its a problem everyone experiences to one degree or another.
the quickest, cheapest, easiest fix available is the "ingalls stiffy torque damper"
quite a few vendors on this site have them available, and they really cut down on that wheel hop.
there are more complex and effective methods....Traction bars...solid mounts....cabs etc...
biggest thing to remember though? race or not.....1/4 mile run or not....if you feel it wheel hop..GET OFF THE GAS. it can/has and will break ****. even on stock cobalts.
Old Nov 7, 2006 | 06:45 PM
e to the x's Avatar
ZZP Billet Tranny mounts, ZZP Poly engine mount, and an Engine Dampner would be a good start. Be warned though that w/o the LSD and the potential for wheel spin still in the mix you risk serious damage to your differential and associated parts. If you can and are willing to, then buy the LSD and get that installed first. Theres some xmas shopping that needs to be done for myself and that will most likely be my investment.
Old Nov 7, 2006 | 06:47 PM
martinsmu's Avatar
yeah quick fix is the dampers, but engine mounts works real good, but then you have alot more vibratiopn comming from the engine. The real solution is learn to drive wisely, (dont floor your car in 1rst gear, quickly press the gas till your close to redline, then shift to 2nd and floor it then. No wheel hop, and you should be just as fast as anyone with the same modds as you with the solid engine mounts. Just learn to drive wisely, its hard but u'll get it. I am still perfecting the system to!
Old Nov 7, 2006 | 06:57 PM
e to the x's Avatar
Hear that on the mounts. Just put in my mounts last Friday and then endured the 4 horu drive into PA. wow did that give me a headache. The vibration is intense. Do not keep coins in your car, or empty cans. The noise gets to be too much with the stereo at 3/4 just to hear it when taking off or slowing down.
Old Nov 7, 2006 | 07:01 PM
martinsmu's Avatar
Yeah, see you confirm what i heard. I was going to get some to facilitate the launching, but i can have a car vibrate that much since my normal driving is mostly highway. Ingalls I heard work well in not extreme condition. I heard a few that broke before....
Old Nov 7, 2006 | 07:10 PM
ReMz's Avatar
i have no wheel hop at all with the Ingalls torque damper. definitely fixes the problem and doesnt vibrate too much on the stock setting.
i have heard of them bending as well; however, this has not happened to me. If something goes wrong, im sure Ingalls would be happy to work with you.
Old Nov 7, 2006 | 07:19 PM
SilverSS/SC's Avatar
Specifically , wheel hop can break an axle , can cause the transmission case to fracture ....which can lead to gear oil leaking on the clutch , causing a slipping clutch too ect ect . I guess that cant be said enuff , because so many people just wheel hop the hell out of FWD cars and dont realize just what can and eventualy will happen .
I put a ingalls torque brace in the short term . It took away about maybe 60% of the wheel hop on the tightest setting . But in the rain , I can still get my car to wheel hop easily if the tires spin and at the dragstrip , though its worlds easier to control with the ingalls ....if I dont watch it I still get bad wheel hop . If you dont plan on modding your car too much past a few bolt ons , youll be fine with a torque brace and some disciplined driving habits .
The ultimate solution is the poly mounts though if ya plan to getting serious with the car .
The motor mount alone will do hardly anything for you . But , the stock fluid mount is beyond bad so it should replaced anyways . The biggest helpers for wheel hop are the lower control arm bushings and the 2 lower trans mounts .
All of them together are kinda pricey , but a new trans is about $2000 ....and thru GM , getting a F35 trans isnt exactly a qwik process .
Old Nov 7, 2006 | 07:22 PM
FDNY101202's Avatar
hows the weapon r tq damper??? j/w?
Old Nov 7, 2006 | 07:32 PM
martinsmu's Avatar
Heard of them, but never heard any good or bad things about them!???
Old Nov 7, 2006 | 07:34 PM
FDNY101202's Avatar
hmmm... same here i saw a tqd from them yesterday and i dont see anyone with then in their sig anyone have info???
Old Aug 30, 2012 | 07:44 PM
turbosmart4's Avatar
I found the number 1 member to get an lnf!
Anyways....I think I have a broken trans case f it..lol
And yes I'm proud of reviving this thread!
Last edited by turbosmart4; Aug 30, 2012 at 07:44 PM. Reason: Automerged Doublepost
Old Aug 30, 2012 | 07:58 PM
kjgcobaltss's Avatar
mounts and traction bars. there is a how to in here on making your own designed like the bwoody ones. cost me 60 bucks in parts and they work great
Old Aug 30, 2012 | 08:00 PM
carstedt's Avatar
i cant see the traction bars workin that great for sum reason..idk id have to ride in sum1's car who has them or sumtin to get a good idea of how they feel
Old Aug 30, 2012 | 09:07 PM
I figured I had trans oil leaking a lil... After I installed the mounts.........
Old Aug 30, 2012 | 09:46 PM
if you didnt live so far away i would giive you a ride in my car lol. i had wheel hop really bad when i was stage 2. put these on right after turbo swap and havent had one bit of wheel hop
Old Aug 31, 2012 | 01:36 PM
carstedt's Avatar
i dont have ne wheel hop as it is..jus straight spin..rotated front/rear trans mounts and ingals td did the job
Solaris99
28
Mar 15, 2017 01:22 PM
Jan 12, 2016 12:01 AM
hacadacalopolis
Oct 28, 2015 06:09 PM
MrInsanityWolf
Sep 29, 2015 04:54 PM
