wheel hop fix?
Old Nov 24, 2010 | 07:32 AM
dontcryemokid's Avatar
wheel hop fix?
ok first off wheel hop sucks. and gm wants way to much damn money for their stupid kit. so if i just buy zzp stage 1 axles and find mounts that will work right. also what mounts should i buy?
Old Nov 24, 2010 | 07:44 AM
dandaman15's Avatar
All you need is rotated transmission mounts. I would look at the OTTP ones.
Old Nov 24, 2010 | 07:47 AM
USMCFieldMP's Avatar
Rattlesnake Race Shop
x2 on Rotated Mounts. That's absolutely all you need.
Old Nov 24, 2010 | 07:58 AM
MT0911's Avatar
^ The above posts are correct. Check with OTTPerformance (Stage 2 Rotated Mounts) and TurboTechRacing (S.T.O.P Mounts). They have Trans mounts that make a significant difference and they are reasonably priced. Some guys on here are putting down great numbers (350+ WHP) and have zero wheel hop. If you do a search on here you will find various threads reviewing these mounts and what benefits that can be obtained by having them. A solid suspension setup (springs, shocks, struts, sway bar) would be worthwhile as well. Good luck.
Old Nov 24, 2010 | 08:02 AM
thanks guys cause yeah i mean i dont have the biggest set up on my car but even when it was stock it was just stupid mad wheel hop. so i figured i got a good amount of monday and friday every1 is having sales so i figured **** ill just buy everything then. so all i need is trans mounts. i dont need axles or motor mounts at all?
Old Nov 24, 2010 | 08:05 AM
and is this what your talking bout Rotated mount upgrade - Over The Top Performance
Old Nov 24, 2010 | 08:19 AM
Yes, that's it.
Old Nov 24, 2010 | 08:38 AM
so am i better with the ottp mounts or the TTR mounts cause i see they have them on sale
Old Nov 24, 2010 | 08:56 AM
Turbalt2010's Avatar
that link there is just upgrading from stage one to stage two, so i think it only comes with one mount. im asuming you want both.
Old Nov 24, 2010 | 09:03 AM
dandaman15's Avatar
You want these and Stage 2
OTTP Rotated Trans Mounts - Over The Top Performance
Old Nov 24, 2010 | 10:05 AM
The OTTP mounts are better than the TTR mounts, imo.
If you wanna be gangsta though... you get the real deal: Powell RaceShop mounts (The original designer of the "Rotated Mount"... and then ones TTR copied to make their mounts).
Old Nov 24, 2010 | 06:16 PM
so i just need the stage 1 right i dotn need to get the stage 2
Old Nov 25, 2010 | 02:03 AM
Stg1 is for 300 or less horsepower, iirc.
Stg2 is for over that.
Old Nov 25, 2010 | 02:07 AM
b00sted06ss's Avatar
Definately get rotated trans mounts.. I have the ingalls td and it is better than stock but wheel hop is still there
Old Nov 25, 2010 | 03:09 AM
yeah but i hope not as bad as my wheel hop is now god is it horrbile and then i think ill jus buy stage 1 for now i prolly wont b to over 300 whp till nxt year hopefully
Old Nov 25, 2010 | 04:13 PM
defo98's Avatar
ottp trans mounts and ingalls torgue damper works like a charm!
Old Nov 25, 2010 | 07:53 PM
lol comeon that can go for any vendor ottp - longtube, then zzp longtubed 2nd
fujita originated the 3" intake then who came next?......
lol its a pointless argumental point
at this point go with whosever cheapest
Old Nov 25, 2010 | 08:46 PM
Do you have the stage 1 or 2?
Old Nov 25, 2010 | 08:49 PM
Ryancobaltss's Avatar
get bigger rims?
i think i might just buy stage 1 we will see. also how easy or hard are they to install?
Old Nov 25, 2010 | 08:53 PM
defo98's Avatar
Stage 1. Its all I need right now since im only on ottps 2.8 setup. I have no wheel hop at all
Old Nov 25, 2010 | 08:55 PM
Yeah I wish the ingalls stiffy got rid of all wheel hop for the price lol
Old Nov 25, 2010 | 09:18 PM
selfinfliction's Avatar
have the tc mounts on mine, no wheel hop... but i also have no traction so that could be the reason for not having any wheel hop
Old Mar 30, 2011 | 10:23 PM
microgab's Avatar
There are 2 products from ZZP...just wondering if any of you guys tried them or compared them to OTTP
Cobalt & Ion ---> ZZ Performance
100$ each
Old Mar 30, 2011 | 10:41 PM
1fastSSBalt's Avatar
Get both front and rear, I have OTTP stg 2 mounts they look cool and work damn good. No wheel hop after the install.
