wheel hop fix?
I have thought about getting mounts as well, or in the near future. not to thread steal but since this is over mounts....
Is the zzp front and rear the same as the stage 2 ottp mounts? I cannot connect to ottp for some reason (never have been able to) so I have no way of checking from pics and the like.
There is a how-to guide, just search how to ottp mounts. Its a super easy install but if you are doing stage 2 it will save a lot of time if you have someone help jack the engine and trans while you are aligning the mounts. If you are doing it solo it will take a few times to get the transmission positioned correctly which means a lot of climbing out from under the car to adjust the jack.
