Wheel hop q?s
Old Nov 13, 2006 | 03:23 PM
SuperEco06's Avatar
Wheel hop q?s
Ok, i know this has been beaten to death, but:
How much wheel hop does it take to actually cause damage?
and
how do you check for damage?
Old Nov 13, 2006 | 04:41 PM
ElChialeux's Avatar
Axles will go first, and they are quite fragile so repeated wheel hop will break them for sure. If you do wheel hop very often (learn how to drive if you do ;P ), you could even damage the motor mount...
Old Nov 13, 2006 | 08:07 PM
SuperEco06's Avatar
i was actually more worried about the accounts of people cracking the transmission case,
Old Nov 13, 2006 | 09:25 PM
03gobluecobra's Avatar
In truth, it only requires one hop to cause damage. You just gotta stay outta the hop as much as you can, and hope for the best.
Old Nov 13, 2006 | 09:28 PM
RaineMan's Avatar
I hadn't experienced any wheel hop problems until it started getting cold here... the tires grip fine in the warmer weather... but when it's cold and a little damp, these tires don't grip for ****... had to alter my driving style a little for the cold... hopefully shouldn't happen again.
Old Nov 13, 2006 | 09:37 PM
tREBs's Avatar
x2! havent had a problem till it dipped below 0 degrees (celcius)
Old Nov 14, 2006 | 11:25 AM
SuperEco06's Avatar
yea i was fine till it was rainin the other, combined with the clutch accidentally dumping itself.
how long does it take for signs of damage to rear its ugly head?
Old Nov 14, 2006 | 11:48 AM
g5mike's Avatar
i have a little wheel hop,but Im afraid when the cams and everything is done Ill have said amount of hp. can anyone tell me if the 2,4 axles are the same or weaker than the ss/sc???
Old Nov 14, 2006 | 01:07 PM
lsjwannabe's Avatar
wheel hop is not your friend try to stay out of the thorttle in first gear.
Old Nov 14, 2006 | 02:06 PM
soccer1061287's Avatar
Hey SuperEco06, to answer your question, if you crack the trans case, you will know right away. In a worst case, it will sound horendous. In a best case, you will leave a puddle of trans fluid under the car. As far as the axles go, again you will know right away. Personally, I got rid of the wheel hop so I did not have to deal with it.
Solaris99
28
Mar 15, 2017 01:22 PM
Jan 12, 2016 12:01 AM
hacadacalopolis
Oct 28, 2015 06:09 PM
MrInsanityWolf
Sep 29, 2015 04:54 PM
