when ur cars of, wat does u boost read
Old Dec 27, 2006 | 11:34 AM
poppagun's Avatar
when ever ur car is off wat should the boost gauge say, mine says vac 20 and all my friends say it should be at 0, should it be?
Old Dec 27, 2006 | 11:36 AM
05BlackCobaltSS's Avatar
It depends. It stays at the position it was in when you turn it the car off. If it was reading 0 when you turn the car off, it will stay at 0. Same thing with 20 vac.
Old Dec 27, 2006 | 11:37 AM
Witt's Avatar
After shutting the car off, turn the key back to the "on" position but don't start the car. It should reset to 0.
Old Dec 27, 2006 | 11:42 AM
TurboTechRacing's Avatar
It is electronic, so when the power is cut to the gauge, the needle will stay at that position until the power comes back; which then at that time it will reflect the current vac/boost reading.
Old Dec 27, 2006 | 12:01 PM
ImaginaryForce's Avatar
Mine stays at whatever I shut it down at, but yea like he said before if you key it on for a second it will reset itself to zero!
Old Dec 27, 2006 | 12:21 PM
BravoPuma6's Avatar
the boost gauge is reading from the ecu, not the vac line. if u open ur door while shutting it off the needle wont have power to zero out.
Old Dec 27, 2006 | 01:35 PM
Acidangel_5.0's Avatar
mine just goes to the bottom.. its eletric.. i dont see it holding a position when off?
Old Dec 28, 2006 | 12:48 PM
PuSha050's Avatar
like turbo tech said...
an electronic gauge will just go to whatever position (for example 20 vac ) when turned off... if u turn the car on but not start it will be at zero
mechanical gauges, when turned off will be at zero (if accurate--i had a boost gauge on my old turbo eclipse that i had to send back bc it "zeroed out" at 2psi)
Old Dec 28, 2006 | 02:07 PM
SSdan's Avatar
My stock boost gauge zero's out at like 1 inHg. What could i do?
tomj77
Oct 2, 2020 05:36 PM
Turbo Johnny
Feb 21, 2019 09:41 AM
allpro666
Sep 23, 2015 07:47 PM
Sean Cummings
Sep 11, 2015 09:35 PM
