Where to buy injectors/pulley?
Old Jun 29, 2008 | 01:52 AM
Zach06CobaltSC's Avatar
Where do you guys recommend I buy 60lb injectors at? Do I need the injector harness or not since I am staged 2? Let me know thanks.
Also, where do you recommend I pick up a 2.8inch pulley at?
Old Jun 29, 2008 | 04:13 AM
Infernokron's Avatar
Someone else mentioned lightning force performance in a different thread. I looked up injectors with harness here.
I got my injectors and harness from ZZP, it looks like they lowered their price to be about the same as LFP, check here.
I'm just about positive you have to get the harness even with stage 2, but I'm not 100% on it. You might try out the search function on that one.
As for the pulley, you can get them from ZZP check here. Or a lot of people go with one of Nate's pullies. Check here for Nate's profile on the forums or I belive Smooth Flow Pullies is Nate's site. Also make sure you have the special tool to remove the stage 2 screws, and a lot of people get some aftermarket screws (can also get those from nate) for the pulley, I guess the stage 2 screws arn't very strong.
Old Jun 29, 2008 | 05:03 AM
it looks like the injectors are just slightly cheaper at ottperformance.com.
Old Jun 29, 2008 | 05:21 AM
juststickit124's Avatar
I have a zzp tensioner for $80 shipped! PM if interested
Old Jun 29, 2008 | 12:15 PM
lsjwannabe's Avatar
you know where to come to, the pulley and injectors are very competetivly priced, and the customer service is bar none.
Old Jun 29, 2008 | 03:11 PM
chad463's Avatar
true enough, ottperformance is great and keep in very good contact with you through out the whole process.
Old Jun 29, 2008 | 10:34 PM
right on. It looks like i am going to be ordering everything from ottperformance this time around. I am grabbing 60lbers, a 2.8inch pulley, injector harness, h/e kit and im pretty sure thats everything i need right...is there some type of pulley remover, or pulley hub or anything like that, that I need? I am already stage 2 and my shop has the "special tool" to remove the bolts.
Old Jul 3, 2008 | 01:15 PM
Armyguy151's Avatar
I have 60Lb Flowmatched Injectors and Harness for sale brand new never used 240.00 Shipped....Pm if you want!!!!
Old Jul 3, 2008 | 02:31 PM
Zooomer's Avatar
Supporting Vendor
At ZZP, we have 60# injectors, harness and 2.8" pulley for $278. You can use coupon code "injector6" for an additional discount if you are a cobaltss member.
dennis69
Oct 20, 2015 04:49 PM
patooyee
Oct 15, 2015 05:11 PM
OrangeCoba
Oct 1, 2015 10:00 PM
Iceberg
Sep 29, 2015 12:33 PM
Iceberg
Sep 28, 2015 01:31 PM
