Where do I get this?
Old Jul 9, 2009 | 06:23 PM
MrSlickSter06SS's Avatar
return style fuel systm, where do I get one?
Old Jul 9, 2009 | 06:25 PM
Black SS/SC 06's Avatar
You mean like this one?
http://www.ottperformance.com/Cobalt...duct_info.html
Old Jul 9, 2009 | 06:28 PM
BlackSSNick's Avatar
what does this do?
Old Jul 9, 2009 | 06:33 PM
More efficient fuel system. Helps when you have higher hp numbers. You need to feed the beast lol.
Old Jul 9, 2009 | 06:38 PM
if your car is mainly stock and you installed this, would it work and give you better gas mileage?
Old Jul 9, 2009 | 06:41 PM
That's not really the point of it so I am gonna go with no.
Old Jul 9, 2009 | 06:43 PM
cobalt123's Avatar
hmmm, subd for later
Old Jul 10, 2009 | 12:20 AM
lol ok thanks guys for the info.
Old Jul 10, 2009 | 03:09 AM
so then what is the point?
Old Jul 10, 2009 | 04:33 AM
Angel's Avatar
A return style fuel system such as the one from OTTP has a few different purposes. First off, many people believe that it helps with the starvation problem of the #4 cylinder but that is yet to be proven, just a theory at this point and a couple other pros is the fact that running a return system will actually keep your fuel flowing cooler as no fuel is sitting "waiting" in the rail exposed to the high heat from the motor rather it just keeps flowing and flowing and flowing and under pressure ofc the injectors rob what they need and the fuel continues to be transferred. Also the adjustability of the regulator that comes with the OTTP kit is very handy to properly regulate the amount of pressure you have your fuel system set to. Oh, and it looks sick!!
Old Jul 10, 2009 | 08:59 AM
StreetDreamz's Avatar
It makes the car easier to idle with bigger injectors (like the 79s/80s) and gives a bling factor under the hood. That's it. Other than that it's just one more thing that could fail and leave you stranded.
Old Jul 10, 2009 | 09:38 AM
BYT*SS*TURBO's Avatar
It gives you more stable fuel flow and consistant pressure over a return style which tend to fluctuate slightly with load. When you run big injectors too, its nice to have the fuel there waiting instead of having the FP controller kick up duty quickly.
Old Jul 10, 2009 | 11:29 AM
eh, to me this isn;t worth the 400 - 500 dollars, im not looking to make my cobalt an all out drag car, so i probably won;t ever need this
Old Jul 10, 2009 | 12:21 PM
Angel's Avatar
I have it on mine and its a dd no problems.
Old Jul 10, 2009 | 02:31 PM
Yeah ur right but at the same time theres guys that dont have a all out drag car, or not that I have ever seen, and they're leanin out they're cars an poppin pistons, so thats why I am probably gonna do it, because another thing are internals are fine for whatever we do, its the leanin out and runin it to the rev limiter, and not getting our temps down far enough thats killin us. Which I have a sick idea on lower temp ideas, but I dont wanna say for now I want it to be a surprise for when im done, just a little broke right now Lol
