who has the methanol kit in their trunk?
Old Mar 25, 2007 | 08:56 PM
jeremie's Avatar
i was reading a while back about locations for mounting meth kits and i saw someone actually mounted all the stuff in their trunk. does anyone know who that is?
Old Mar 25, 2007 | 09:05 PM
Ljavy17's Avatar
Old Mar 25, 2007 | 09:09 PM
DTM2188's Avatar
Mine is in the trunk, but I haven't gotten it back from the shop yet. I may be able to answer a question if you have one.
Old Mar 25, 2007 | 09:32 PM
jeremie's Avatar
awesome, the guy i was looking for!
i have a few questions actually
does the pump work efficently from the trunk?
did you mount the tank in the trunk?
did you run the lines inside or outside of the car?
ill think of more eventually but thats all i got
Old Mar 25, 2007 | 09:47 PM
patathSS's Avatar
hey jeremie, mine is in the trunk. let me see if i can dig up some pictures
I was told the pump is a pusher style so no problem with the way I mounted it, close to the tank. I ran the lines inside the car and through the firewall. Let me try and find a pic.
Tank and pump mounted in trunk
Hose routing
And where the line runs under the hood. Find it?
Old Mar 25, 2007 | 09:49 PM
jeremie's Avatar
sweet. i like the tank lol.
where'd you end up sticking the nozzle?
Old Mar 25, 2007 | 09:50 PM
patathSS's Avatar
Right in the rubber connector before the throttle body....
Old Mar 25, 2007 | 10:05 PM
t5munoz's Avatar
Dude you can use your windshield washer tank meth is almost the same as windshield washer fluid
Old Mar 25, 2007 | 11:52 PM
06noscobaltss's Avatar
Mine is also in the trunk. Looks almost exactly like the pics up there do! I have my lines also inside the car, and inject into the top of the intake tube right before the rubber piece that way its screwed into the intake and does not leak, or move around
Old Mar 25, 2007 | 11:56 PM
0redline6's Avatar
hmm im gonna have to mount mine in the trunk now.. keeps it a bit cooler i would assume also... ill have to incorporate it in my trunk!
Old Mar 26, 2007 | 01:09 AM
wrxbeater11's Avatar
Yup, best bet in the trunk. Thats where I keep mine in my STI and will deff be adding a meth kit for my Cobalt.
Old Mar 26, 2007 | 01:10 AM
jeremie's Avatar
or i can use my wash fluid tank for washer fluid. and since snow performance's boost juice has a higher methanol content in it, i think i'll stick with it. washer fluid is for cheap asses and it doesnt work nearly as well as boost juice.
i think i'm going to mount my tank over on the passanger side and mount the pump under my carpet thing, by my spare tire and battery..and maybe mount the controller inside somewhere.
are your kits running off the maf signal?
Old Mar 26, 2007 | 01:32 AM
euthanasia's Avatar
Trunk Mount
This is the best set up.
http://www.putfile.com/pic.php?img=5032708
Old Mar 26, 2007 | 07:33 AM
DTM2188's Avatar
My tank is mounted on the passenger side as well. The pump is mounted under the carpet where the spare tire is. All wires and hoses are ran inside the car just like everyone elses. I have the TB Spacer from CA for where the nozzle is.
Old Mar 26, 2007 | 08:09 PM
patathSS's Avatar
Originally Posted by euthanasia
I would like that tank. They just want a lot of money for it. Maybe in the future.
Jeremie be careful of mounting your tank where I think you are. You may get a hard time from people at the track about it being so close to the battery. I know I thought about it but that was my concern. I know Heartland Park gave me a hard time just when I pulled the carpet piece out of the trunk.
Old Mar 26, 2007 | 09:26 PM
blueta's Avatar
I was never a fan of putting it in the trunk. Are you guys using check vavles/solenoids to prevent fluid from being sucked out of the tube? If not I could see it being a problem having the pump catch up because of how fast our cars make boost. From what I see in the pics it does look like you have some kind of cv though. Why not try and mount it on the left side of the engine bay where there is that empty spot with the 2 studs on the strut tower? Yes there is methanol in washer fluid, but you are never exactly sure of how much the difference from bottle to bottle is. That's why I stay away from it.
dennis69
Oct 20, 2015 04:49 PM
Sep 28, 2015 12:51 PM
grampss
Sep 27, 2015 08:51 PM
metroplex
Sep 27, 2015 07:48 AM
