Who is spitting flames??
Old Mar 15, 2007 | 10:26 PM
Maxim_X's Avatar
I'm just curious to see if anyone is seeing some flames out of there exhaust. I'm sure my car would let some fly if I took the cat out, but if it doesn't, than its kinda a waste to get just a catless DP. I'm assuming one of the few of you with side exhaust is seeming it, and maybe some with the 3" headrback?
If you get flames, post your exhaust specs please.
intense_SS's Avatar
i spit flames man!!!!
Old Mar 15, 2007 | 10:27 PM
Shortbus's Avatar
If your runing rich, or side exit catless you will, its not really a waste to take out your cat, you can add timing when taking out your cat, and run race gas, and add more timing, more timing= more power.
Old Mar 15, 2007 | 10:28 PM
JohnnySasakiMGS's Avatar
Easy there Yoda.
Old Mar 15, 2007 | 10:44 PM
intense_SS's Avatar
i got a 3" catless side exit and i spit some flames!! its sick with all the poping!!!!
Old Mar 15, 2007 | 10:51 PM
memphisr24's Avatar
You can add timing just by removing the cat!? or do you mean removing the cat and running race gas?
Old Mar 15, 2007 | 10:56 PM
Maxim_X's Avatar
Are you going through a resonator and muffler too?? THe popping is sick with it when decelerating in my car. But, I figured because I had no muffler. I really should get a driving video of the cutout open. I'm leaning towards getting a catless DP now.
Any videos?
Old Mar 15, 2007 | 10:57 PM
Shortbus's Avatar
Yes you can add timing just by removing the cat, when i had the 3inch catless d/p on my car, we were able to add timing via hp tuners, thats where most of the power increase comes from when removing your cat on the ss/sc. I was also saying, taking out the cat, and runing race gas, you can add alot of timing.
Old Mar 15, 2007 | 11:00 PM
intense_SS's Avatar
i have no muffler,,just a resonator and it sounds excellent!!
Old Mar 15, 2007 | 11:03 PM
powerz's Avatar
There is a guy here that has an older truck that has drilled and put spark plugs in his exhaust and a nozzel to spray fuel before it has about 18inch flames I have seen him once at night spraying it.pretty cool
Old Mar 15, 2007 | 11:05 PM
Toronto SS's Avatar
Im spitting hot fire!
Im sorry I couldnt resist.
Last edited by Toronto SS; Mar 15, 2007 at 11:05 PM. Reason: Automerged Doublepost
Old Mar 15, 2007 | 11:07 PM
memphisr24's Avatar
How much timing!? like 1-2 degrees? Yeah, i'm running on 100 unleaded and wow....I already gained 7 degrees and still going to try and get more
southal cobalt
Sep 9, 2015 08:21 AM
SiloGM
Sep 7, 2015 11:04 PM
mcphatty
Mar 11, 2006 10:30 AM
