Whos got a crankshaft they can look at for the J-community?
Old Jan 27, 2010 | 08:15 PM
rare5spd's Avatar
Either a LSJ or LE5 crank applies to the following. If you remove the crank trigger, underneath there is said to be the same crank trigger the j-body eco's have casted into the crank. Someone on the HPT forums claimed there is, and we would like to confirm this.
Thanks
Bryan
Old Jan 28, 2010 | 06:22 AM
oldskool's Avatar
Bump - this is a possibly huge development.
On a related topic, what keeps LSJ guys from swapping an entire LE5 bottom end? I heard the clutch/flywheel combos are different (weaker on the LE5), but other than that you get 20% more displacement and a strong bottom end.
Old Jan 28, 2010 | 11:27 AM
mrbelvedere's Avatar
what r u talking about
Old Jan 28, 2010 | 12:57 PM
oldskool's Avatar
::sigh:: There is a ring on the end of your crankshaft that, together with a sensor, tells your ecu how fast your engine is spinning. This ring is different on jbody ecos vs the LE5/LSJ. Recently on hptuners.com/forum, somone made the claim that you can unbolt the ring on the LE5/LSJ wheel from the crank, revealing underneath the cast on ring that the Jbodies use.
No one can confrim this yet.
If in fact the ring that the jbody uses is underneath, it would make bottom end swaps much easier, and most imporantly, it would make them play nice with the jbody ecu.
Old Jan 28, 2010 | 01:35 PM
Josh@ottp's Avatar
It's not there on the lsj crank I have here.
Old Jan 28, 2010 | 01:36 PM
selfinfliction's Avatar
i heard that you can swap a ls7 crank with an ecotec with nothing more than extra strength duck tape and packing grease
Old Jan 28, 2010 | 01:38 PM
roser4888's Avatar
LOL
Old Jan 28, 2010 | 01:48 PM
brutus.nova's Avatar
REALLY? omg i gotta do this....
Old Jan 28, 2010 | 01:49 PM
ralliartist's Avatar
hahahahahahahahahahahahahahahahahahahahahahahahaha haa
Old Jan 28, 2010 | 03:43 PM
bolus's Avatar
Not on the LSJ crank from what I remember. just some nubbins that the reluctor ring bolted too
Old Jan 28, 2010 | 07:01 PM
that was sarcasm if you didnt catch on...
Old Jan 28, 2010 | 07:17 PM
roboticfister's Avatar
Old Jan 28, 2010 | 07:29 PM
bolus's Avatar
we need a term for "one who is sarcastic who does not recognize sarcasm" like a gynecologist who cant tell the difference between a ***** and a vagina
Old Jan 28, 2010 | 07:59 PM
there's a word: nescience
Old Jan 28, 2010 | 09:15 PM
i know what the relucter/trigger ring is for and yes you can unbolt it i haavent seen a cast on ring though
NJHK
Feb 15, 2014 12:29 PM
Pyros777
Dec 29, 2013 02:59 PM
victory_red_SS
Jul 10, 2007 09:14 AM
WopOnTour
Nov 27, 2006 10:10 AM
Bad GTP
May 17, 2006 02:46 PM
