Why #4?
I thought that was the problem. Not having a returnable fuel system. returnless is what we have isn't it?
Speaking of heat destroying number 4, what kind of coolant temps are you guys seeing in traffic? I have seen 220 sitting in pittsburgh traffic on an 85 degree day. To me this is more than I'd like to see. I had 600 HP bored out 454 in a chevelle in North carolina and never had the coolant temp over 200.
Anyone else seeing 220 or more???
thats a big ass whipple S/C. Whipple was going to make a w75ax, which would have been perfect for ours cars but to my knowledge they never put it into production. Or maybe they did but I can't find it offered anywhere.
Back on topic: COOLING
I think he means the higher coolant temps. He's saying that with HP Tuners you can adjust the fan to turn faster at a lower temp to keep it cool. If i'm not mistaken it's not abnormal to climb up to around 215 or so after some "spirited" driving and then sitting in traffic, although it wouldn't hurt to keep that from happening.
If you aren't moving then the coolant isn't being cooled in the radiator, well at least enough to lower it on a hot day. So the fans need to move air and do that job, in lou of the car moving through the air. Since the fan doesn't kick in until 196 degrees the thermostat opening won't really help cool the coolant if you are just sitting there.
So even with a lower temp thermostat you can't really get the car below 192 sitting in traffic. 192 being the lowest temp you can command the fans to turn on.
Note:
If you run the AC that can cause the fans to turn on regardless of the ECT due to AC coolant pressure.
Well I can tell you that JapEatr's tune has the fans coming on earlier and at a higher percent. When it is 80+ degrees and 90+ humidity cooling is a challenge for the stock fans. He really does need a thermostat
With the way the LSJ operating system is configured it's not possible to get the fans to come on cooler that 192 degrees using the standard map. If the car isn't moving a lower thermostat isn't going to keep the ECT from rising. You could of course rig up something to get them to kick in earlier with a bypass.
Today it was approx 95 degrees here in Houston with high humidity of course. I was sitting in traffic for long periods of time and when my temp would rise too much I just cut the AC on to MAX and recirc (Kicks the fans on). This kept my coolant temp at around 190 degrees for over an hour.
True, I can drop the temp by simply turning on the A/C and it drops rapidly. A thermostat IMO has nothing to do with it as it runs 170-180 90% of the time. If I remember correctly about a year or so ago I saw a thread where others were also seeing this while sitting in traffic so I didn't think much of it. However I would like to keep the temps down as much as possible, say 100% fan at 200 degress. HP tuners here I come.
Keep in mind this is sitting in traffic, not at a light.
I believe it is more related to the fuel pump most people blowing the pistons are on 60# injectors so we are wprking the stock pump twice as hard to put the fuel out. Anyone ever think of running two fuel pumps like the solstice gxp.
how would that work? putting 2 fuel pumps and then 2 fuel lines, then having 2 seperate entrances into the fuel rail? and then a line in the middle of the rail so the excess gets sent back to the tank?
