Why 60lb injectors why not larger
For just runnin an extra set of injectors its really not that bad... you can even set it up to be boost referenced to make tuning even simpler... I had a similar setup on my RX-7 had a set of 1200cc for high boost... (526 whp 1.3 rotary) and 540 cc primary and 750cc secondary.
I forgot which one it was but maybe HKS has a add-a-injector setup I"m gonna attempt to use
OK BD it's obvious you don't know anything about this motor.
Do some more research and listen to the people who know what they are talking about.
You haven't done either of those.
Listen to yourself....160lb injectors WTF?
60lb. injectors have a tough time maintaining idle in the 2.0
With a 2.5" pulley the IDC's are only around 65%
Originally Posted by bdwarr6
i know alot about this motor you have no clue what i have ordered
If you know so much tell me, what causes these idling problems with the 60lb injectors?
hey ctss/... I was hitting 82% idc with 60's a 2.5 and meth inj... I was also running a large amount of timing... but when it was in the high 30's one night I touched 82% at 7200 rpm at a 11.4:1 afr
so why don't you tell us? because not for nothing, when you talk about using 160#ers, it kinda makes you look like a moron...
I'm talking straight 2.5" pulley and 60lb. injectors.
Either way my point is this 160lb injector talk is nuts.
ya'll are talking a bunch of fluff to me atm..but what does ordering parts have to do with knowledge of a motor? ya'll are bickering but nobody has said this?
just adding some gas to the flame
I am officialy out of this thread. Later......
im not saying i give up w/e the 50lbers dont have as constant a flow as the 60lbers do they will vary alot
I wouldn't unless you have a wideband set-up at the very least. Even with a wideband you won't be able to monitor IDC. The big fear is the injectors going static at high RPM's due to IDC of over 100%. That could cause serious issues if you are an unlucky person. I tell everyone the same thing, at the very least get the gauge, you'd be better off with tuning and the gauge; however, most will tell you tuning still won't solve the IDC issue unless you set the rev limiter lower.
I'm still waiting for someone to comment on my questions about the 50# injectors available.
I would say that it isnt a problem with the ecu but with the programing. 60lbs is not that big of an injector. I can see that the stock ecu does have its limits however they should be somewhat easy to get around. Especially if your running hptuners. Now as for idle big injectors are generally harder to control on any car. Most people just bump up the idle a tad. 50lbs unstable? Nope. Your going to have to tune to them but they should be more then fine as a stepping stone if you really want them. Personally if you think your going to push your car more in the future you might as well plan ahead and get the 60lb injectors. They are there for someone that is just leaning out slightly and wants a lil bump to stay in the comfort level 80% duty cycle. Something as simple as a safc neo piggy backed to the stock ecu with hptuners might be all that you need has anyone tried it? The only other thing that is close to being as cost affective to try out would be megasquirt. However not many people want to take the jump to the full standalone.
I have been looking into 50s for a few weeks now. They would be easier to tune your car with them as the PCM will be able to handle that size injector. As for how much they will be able to handle no one knows as I dont beleive anyone has tried them. There is no need to go to larger than 60s yet but im sure someone will need to eventually but till someone actually maxs the 60s whats the point and as far as going with someting like 95s or something that larger I dont think that will ever happen with these cars.
Does anyone know the Brake Specific Fuel Consumption. Im sure someone was on a dyno and has that number handy. I wouldnt run the 50lbers without some kind of tuning. Now would be a good time to get a tuning section on this site
heres some injector claculators for people to play with.
http://www.rceng.com/technical.htm#WORKSHEET
Ok i just went with the standard .6 bsfc
These numbers are rough. Not exact
But say you want 400hp at 80% duty cycle.
At 58psi fuel pressure your going to need roughly 64lb injectors
280 42lb
300hp 50lb
375 65lb
400hp 65lb
475 75lb
525 85lb
575 95lb
1000 165lb
600 97lb
650 100lb
These are just generalized calculation please dont take them to heart. It can chanbe with each persons setup. And proper tuning and monitering should always be used.
280 42lb
300hp 50lb
375 65lb
400hp 65lb
475 75lb
525 85lb
575 95lb
1000 165lb
600 97lb
650 100lb
