Why aren't the SS' running high 13's 200+ whp stock?
I was just wondering that why aren't the Cobalt SS' running high 13's when some of them are putting down 200-230 whp stock + intake? My GTP with just a smaller pulley (3.4 vs 3.8 stock) short ram intake, reprogrammed pcm, and ubend delete was running high 13's. I never had it dynoed but from other people on the forums I could estimate about 220-230 whp and that was heavier car at 3400+lbs.
If I do a GM Stage 2 + intake on my new cobalt will that possibly get me into the 13's if I can drive it and launch it perfectly??
I would say traction is a big issue. Unless everything is perfect, I spin all the way through 1st, and through some of 2nd. It sucks I have to launch at a ridiculously low RPM. But, there is hope, traction bars, torque dampeners and new mounts get wheel hop and spin way down.
Wheel hop is a major deterent for many to aggressivly launch. That is why our times suck IMO. We have terrible 60' times. Also first gear is practically a granny gear, but second is too tall to start in.
That answer is easy since i own the fastest Impala and Cobalt and the Impala is the same as your GTP,
TORQUE
But i will tell you something, line your car and Cobalt up on a hot day and the Cobalt will take you. Your 13.9 was on a cold day
Originally Posted by DC52NV
not just all bout tq. if that were the case then hondas would not be hitting below 12's.
Tell that to the S2000 i HALFTRACKED this past tuesday. I think he ran 14.8@92 with MORE HP than me!!!!!!!!!!!!!
Yea, TQ means nothing
Yea Its all traction. I mean I am doing 13.7 w/ a crappy 2.25 60 foot and that was pretty much w/ stage 2 and bolt ons. Also in 90-100 degree heat w/ stock crap tires taht where going balt (I have 13,000 miles on my car now)
If I could get a good launch IM sure I am capable of low 13 second passes. I am waiting for it to cool down and put my P nero's back on and see what I can do. they seemed to be stickier tires even in the cold.
When I had them on I was doing 2.1 60 foots before stage 2 in cold weather, so I am doing 2.3's now with the stock tires and 100 degree heat when they should be warmer and stickier, but they arnt.
Originally Posted by FAST06SS
Ok wise one, i have n't added ANY HP to my car but added almost 40lbft of TQ and i gained 5mph and .6 tenths off in the 1/4 with just TORQUE alone. I could give you many more examples but obviously you don't understand. The honda's have TQ, either when they hit thier 200hp nitrous or at 8500rpm.
Well it really is a combination of everything. Torque is important, but traction seems to be the biggest hurdle to overcome. The traction issue is tough because the car is FWD, plus 1st gear is too short and really helps promote wheels spin.
TORQUE
TORQUE
never said tq doesn't mean anything. all i said is it's not all about tq. i knew you would react like this, that is why i deleted my post. you seemed to quote me before i deleted it. oh well.
I don't have the GTP anymore, got the Cobalt the other day.
Originally Posted by HackAbuse
Drag Radials.
You guys are right about the SS first gear though. I get the same 60' times as a stock SS/SC with my LS Auto Four Door
https://www.cobaltss.net/forums/show...2&postcount=15
Stock Buick Roadmasters can pull 2.2 60'. What does it matter that your car with 140 or whatever ft.lbs can pull the same 60' as a car with 190 ft.lbs.????
i would say in stock form its gearing only thing holding a good driver back from a 13 sec slip. Even though i still think even with everything in your favor short of the timming mechine messing up a stock cobalt cant pull a 13 sec pass
Originally Posted by CoBOT
Where did you add the 40ft.lbs??? The horsepower didn't increase in the same area??? Torque is never alone, as horsepower is never alone. But in MOST racing situations (read:not all) horsepower is considered more important.
You're clearly showing your lack of the ability to do a search. Rob has posted his dyno sheets and gains since day one. Going from a 2.8 to a 2.5" pulley didn't really net him much power, but a bunch of torque. Do a search for Rob's threads and posts and you'll see.
Originally Posted by 03gobluecobra
Traction and gearing really hurt this car in the 1/4 mile.
