Why don't more people go GM Stage 3?
Old 10-19-2014, 03:44 PM
LScreaminJ's Avatar
Just curious as to why people don't go GM stage 3 over other stage kits. I know each have their benefits but the PCM GM offers with all the options seems to be pretty unique. Also, if someone is buying ZZP's stage kit and getting a 2.9 pulley, why not get GM stage 3? Just curious to hear people's reasons. I kinda wanna go GM stage 3 just to be different and eventually utilize the 50 shot of nitrous feature.
Old 10-19-2014, 04:03 PM
nhanson's Avatar
Thats cause stage 3 sucks. Most go well beyond stage 3
Old 10-19-2014, 04:13 PM
LNFTX's Avatar
Gms3 may not be as good as a custom setup with hp tune but it doesnt suck. I think most dont use it because the ac doesnt work without modifications. I thought the zzps3 had all the features of the gm but the ac works?
Old 10-19-2014, 04:29 PM
slapbetcommissioner's Avatar
Lots of people go ZZP s3 and them go even smaller on te pully.
No one goes gms3 because of Ac delete and $$
It made sense when it first came out but not now. Considering no one is worried about warranties and such.
Old 10-19-2014, 05:08 PM
How much does gms3 cost?
Old 10-19-2014, 05:13 PM
LScreaminJ's Avatar
GM Stage 3 is around 650 which is cheaper than zzp stage 3 by the time you add everything you need. Can you use HPtuners on GM's PCM? Also from what ive seen, they put down the same power as zzp stage 3... both around 250whp
Old 10-19-2014, 05:15 PM
[QUOTE="LScreaminJ;7422253"]GM Stage 3 is around 650 which is cheaper than zzp stage 3 by the time you add everything you need. Can you use HPtuners on GM's PCM? Also from what ive seen, they put down the same power as zzp stage 3... both around 250whp[/QUOTE
Old 10-19-2014, 05:25 PM
LScreaminJ's Avatar
What were you trying to point out there?
Old 10-19-2014, 05:30 PM
mrbelvedere's Avatar
the gm stg3 pcm is an awsome and unique unit but the only draw back is u cant tune it its locked up and it kills the air compressor so no a/c
no it dosent suck its a great piece for those who dont want to do a bunch of **** and still have a clean running car
Old 10-19-2014, 05:38 PM
LScreaminJ's Avatar
That helps a lot, thanks! Is that estimated 249whp or whatever with or without bolt-ons
Old 10-19-2014, 05:49 PM
LNFTX's Avatar
To take full advantage of the s3 youll need full exhaust and prolly want some valve springs and such to rev it out a little more reliably
Old 10-19-2014, 05:50 PM
Don't quote me on this but I believe the gms3 is an add on to gms2 so you would need both. Where as ZZP s3 can go on a stock car. Making ZZP significantly cheaper
Old 10-19-2014, 05:56 PM
LScreaminJ's Avatar
Ah I see, if this is the case then it totally makes sense. Right now I do have full bolt-ons and I was considering cams and valve springs in the future. Might be a dumb question but would that require an additional tune, adding cams and valve springs?
Old 10-19-2014, 06:53 PM
Also I think some of those options are cooling mods gm doesn't offer so that's even better
Old 10-19-2014, 07:07 PM
LNFTX's Avatar
Different cams will require a tune not springs
Unless you get gmr cams
Old 10-19-2014, 10:14 PM
valve springs are not needed
you get a pcm dual pass enplate pulley and juice wires you can source gm42# inj elswhere and a belt
Cobalt Stage 3 2006-07 Performance Upgrade Kit 88958719
any cam change will require a tune and most cam changes will require a spring change also but the stck lash adj wont handle much
Old 10-19-2014, 10:44 PM
South Central *********
JapEatr's Avatar
Where is staged07
Old 10-19-2014, 10:55 PM
LScreaminJ's Avatar
I pm'd staged07 a few questions but didnt get a reply. It has only been a few hours though haha
Old 10-19-2014, 10:56 PM
LNFTX's Avatar
^isnt he running gmr cams on s3 tune
Old 10-19-2014, 11:03 PM
no he is not zzp stg1
Old 10-20-2014, 06:37 AM
LNFTX's Avatar
Gottcha
I was surprised to learn he is running a non stock cam on gms3 just couldnt remember which one I really thought you needed to tune for any cam change
Old 10-20-2014, 07:28 AM
Administrator
Administrator
Staged07SS's Avatar
Such a typical ignorant statement.
You will need springs when you swap to performance cams.
ZZP stage kits do not have any of the features of the GMR S3 PCM. Features like adjustable rev limiter, high octane mode, and calibration for a 50 shot.
Old 10-20-2014, 07:38 AM
Administrator
Administrator
Staged07SS's Avatar
If anyone wants to see what an M62 car can make with GMR S3, look up the user micro.
His car made 260 whp, full bolt ons, 93 octane.
GMR S3 responds very well to breathing mods, ie. exhaust, ported head, cams, etc.
It was tested and refined on time attack.
I spoke many times with the engineer (Bill Duncan) who worked on the calibration, and built my setup with help from him.
Gottcha
I wouldnt have if I didnt get the ok from Bill Duncan, and in the end my setup works great.
All parameters are in check, fuel trims, a/f ratio, kr, injector pw's, etc. No lean spikes & a/f holds throughout the pull.
I dont go on here on the weekends.
PM's answered.
Old 10-20-2014, 10:27 AM
LScreaminJ's Avatar
Is the ZZP canned tune more aggressive than GM's S3 tune?
Old 10-20-2014, 10:29 AM
Administrator
Administrator
Staged07SS's Avatar
No, not how it comes as a canned tune. Although, you can have ZZP tweak it how you want.
GMR S3 commands an 11.3 afr, 22-23 degrees timing advance with 93 octane, 25-26 with race gas.
The ZZP tunes do not run that kind of timing, also because they come with much smaller pulley options.
The features of the GMR S3 PCM are wonderful as well. I can adjust my limiter from 6.5k to 8k anytime I want. High Octane Mode is a blast, and the 50 shot calibration is a bonus.
w/o hp tuners, you will not be able to have that kind of flexibilty with a zzp stage kit tune.
Quick Reply: Why don't more people go GM Stage 3?
