Diamonds meant for the lsj are going to do the same thing
(Post 7558352)
Part number 10000. |
you will need to use 2.2 rods as well
Originally Posted by 07blackg5
(Post 7558359)
Right from the L61 build book
"The 2.0L LSJ ECOTEC engine has forged steel rods similar to Small Block Chevy “Pink Rod.” The forged steel rods are made of high quality material and have a cap screw 23 mm small end, and a full floating bronze bushing. These rods are available through GM under part number 12755126. These rods require GM Performance Parts piston set part number 88958634 to work with the stock 2.2L crankshaft" |
i know a couple of people who ran a 2.2 crower rods in a lsj with lsj pistons raised the compression 1 point
i am sure some people ran the lsj rod and piston years ago get an accurate measurement may not be as far as you think
Originally Posted by ECaulk
(Post 7558374)
"The 2.0L LSJ ECOTEC engine has forged steel rods similar to Small Block Chevy “Pink Rod.” The forged steel rods are made of high quality material and have a cap screw 23 mm small end, and a full floating bronze bushing. These rods are available through GM under part number 12755126. These rods require GM Performance Parts piston set part number 88958634 to work with the stock 2.2L crankshaft" the book is wrong on the rods they are not a forged piece |
Also those pistons are impossible to find
(Post 7558401)
Fuck that lol. All to use a stock rod?
Eagles and wisecos are 780 shipped on ebay |
i doubt jegs stocks ecotec parts those pistons will be a custom order
Not to mention if its the special gm piston they havent been made in forever
Originally Posted by mrbelvedere
(Post 7558392)
i am sure some people ran the lsj rod and piston years ago get an accurate measurement may not be as far as you think the book is wrong on the rods they are not a forged piece |
So can anyone tell me what would be need to make a 2.1 out of a 2.4 block using the crank from the 2.0 thanks have been looking but can't seem to find any info on this subject
wiesco makes the 88mm pistons that fit on the LNF rods, then just use a 2.4 block and a 2.0 crank. I think zzp sells a crank sensor spacer that you might need.
The only issue is the machining of the LSJ top end to fit the L61 would be something I know nothing about.
Originally Posted by annamartino
(Post 7756292)
