wich wire?
Old Dec 23, 2005 | 10:03 PM
1MEANSS's Avatar
wich wire?
hey guys just a quick ?.... hey what color wire did you guys use to hook up your aeroforce gauge?? also if the batt is unplugged the dumb airbags wont go off if i take the pillar pod off will they...i no its a dumb ? but you can never be too sure with gm!!!!
Old Dec 23, 2005 | 10:11 PM
Doc's Avatar
Doc
It should be the pink/red one. There are 2 wires that carry current, one is one when the car is on and the other is set with the headlights. The pink wire shares the side with the other one that has power to it.
Old Dec 24, 2005 | 12:30 AM
1MEANSS's Avatar
i got it working thanks again
Old Jan 13, 2006 | 12:48 AM
silverSS's Avatar
I bought the interceptor and spliced it into that pink wire and it works fine EXCEPT the only thing i want to see...KNOCK...WONT WORK!! WTF!!! should I splice into another 12V is that why im not seeing it on my gauge?? it doesnt even have an option for it on the gauge...while it says it on the box
**note...not the cobalt SS editon, but says in directions and on box that it should record knock...so everyone
WHICH WIRE DID YOU USE??
Old Jan 13, 2006 | 07:47 AM
Doc's Avatar
Doc
You need to contact Aeroforce about that one. I see it on mine. There are 2 wires that go to the 'old' boost gauge that have power. One - the pink one, has power when the car is on. Two - the grey one, has power when the lights are on. I tested it out with a circuit tester. You can use another wire, just run the 'red' wire to the fuse box. Its much easier to 'add a circuit' to the wire which you know has power.
If your gauge works you've hooked it up correctly. If you don't have a certain option and the gauge works, its not going to matter where you get power from, its the gauge. Contact Aeroforce and tell them you have an issue.
just my .02 cents
Old Jan 13, 2006 | 07:51 AM
1MEANSS's Avatar
well if im correct only the ss one show knock on our cars.....so i would see about trading it back for a ss one.....
Old Feb 8, 2006 | 09:05 AM
silverSS's Avatar
I have a mechanical boost gauge, so where should i run the white wire for the interceptor gauge???(the 12V power source for the interceptor)
Old Feb 8, 2006 | 12:10 PM
theBLUEone's Avatar
I used a tap into the interior fuse box for the power supply, and I believe mine reads knock..
Also, how do you guys have it mounted in there? Mine is just sitting in the hole, it doesn't seem to mount like the stock one...
Old Feb 8, 2006 | 12:33 PM
silverSS's Avatar
well im mking a custome 2 gauge pod, i was considering producing them and selling them on the site depending on how good it looks, im in the process of it right now, I will have pictures up soon.
Old Feb 8, 2006 | 04:19 PM
theBLUEone's Avatar
For us with side curtain airbags, we cannot go this route....
Old Feb 8, 2006 | 04:26 PM
myoshizawa819's Avatar
Why? The side air bag is in the headliner not the A pillar.
Old Feb 8, 2006 | 05:20 PM
Doc's Avatar
Doc
yea it is....just not where the gauge is.
Old Feb 8, 2006 | 05:48 PM
silverSS's Avatar
Ill give my idea away but here i what i was thinking..
Getting a 2 gauge universal pod from (anywhere)..autozone advance auto etc. then molding it onto a side curtain airbag a pillar (non ss) and painting it then BAM! gauge pods!
Old Feb 13, 2006 | 12:40 AM
silverSS's Avatar
Just trying to picture it...let me get this straight..
The fuse box on the passenger side, I just run the white wire to where? Sorry im not to good with a lot of electrical stuff (know the basics) Just want to do it right
Run it into where is the main question? Just plug it into one of th holes then get a fuse? which amp fuse?? LOL!!!
Old Feb 13, 2006 | 12:44 AM
Tofu's Avatar
Yeah I'm not getting this at all LOL. I tap the red wire from the aeroforce gauge into the pink wire on the harness for the stock gauge? Where/how the heck do I route this thing so wires aren't popping out all over the place?
Old Feb 13, 2006 | 01:03 AM
silverSS's Avatar
Dont tap into the boost gauge, thats what i did with the stock gauge, now i have a mechanical one....
But I have the existing wiring harness for the boost gauge can i just tap into that thing?
Old Feb 13, 2006 | 09:08 AM
theBLUEone's Avatar
Ok, run the cable for the OBD-II port up through the dash, so that the connector to the guage is where the stock boost guage harness is.
You have to go to autozone, pepboys etc. to get a fuse tap made by Littel....
Once you have your fuse tap, run the red wire from the OBD-II connector to the passenger side fuse box, I ran the wire under the dash to hide it away...
Use the fuse tap and figure out an accessory that is on only when the car is on, I used the sunroof fuse, now place the fuse tap in the space of the accessory. Put the accessories fuse that you are tapping in the empty fuse bank, there will be 2 fuse banks on the fuse tap one for the original accessory so you still can use it and one for the guage.
Soldier or splice the red wire to the wire on the fuse tap..
Plug the OBD-II connector to the OBD-II port.
Turn the ignition to the On position and there you go your guage should light up, if not go back and check your connections....
Hope this helps...
Old Feb 13, 2006 | 09:37 AM
RaineMan's Avatar
So if you do that... and the side airbags deploy... you get hit with the pod... or maybe the pod will block the bag from opening properly... it'd be like glueing something to your steering wheel...
it's best not to mess with the airbags....
Old Feb 13, 2006 | 12:20 PM
silverSS's Avatar
The worst thing that could happen...is getting hit with a nice pod to the face Think about it, if you buy a new a pillar that has the side air bag option it is going to deploy just like the SS/SC one would, so if you glue a pod, or a pencil to your a-pillar its not going to make a differnce
Old Feb 14, 2006 | 12:03 AM
Tofu's Avatar
got mine working and routed, frkn sweet device. I'm measuring 15.6 psi near redline on the inlet supercharger pressure vs around 13.5psi on the stock gauge...I found that interesting.
Old Feb 18, 2006 | 03:11 PM
05_Blue_B10WN_SS's Avatar
I'll be purchasing this gage come monday. Where do i find this OBD-II connector? I understand picking up a power source from the fuse box, and routing it neatly over to the gage pod. But what else is needed to be done? Trying to peice it together so i know what to do when i get it.
Tupp
2.2L LAP Performance Tech
Jan 2, 2016 12:04 PM
dennis69
Oct 20, 2015 07:39 AM
ernnyyes
Oct 2, 2015 05:16 PM
c_m_shooter
Sep 27, 2015 04:40 PM
jmelton327
Sep 26, 2015 10:04 PM
