Wideband
First off your wideband needs it's own power source to be as accurate as possible. Sharing a power wire for a wideband is generally a no-no! Use a add-a-circuit for the widebands power and tap it into the passenger side center console fuse panel. Run the main harness wires for the sensor into the car by punching a hole in the rubber plug on the firewall. As for the diming stuff, IMO that's just a waste of time and I'm not even sure it can be done on an aftermarket gauge.
You can pull any fuse for it as long as you replace the same amp fuse in the part of the add-a-circuit for that function. Then you pick what amp fuse you would like for your new power supply which is the one next to where the wire comes out.
If there is an empty spot that is in the panel that wil supply power you can plug it into there too. Just make sure that the power shuts off when the car does.
I use one for my meth kit in the engine compartment fuse box, and another one for my wideband inside the car like I described. I did the same for my Integra's wideband as well. I love the add-a-circuits because they are easy, quick, and can be removed without a trace.
any anyone tell me what the grey and tan wires are that go to the stock boost gauge??
^ANYONE
^ANYONE
Last edited by TxLonghorn#1; Apr 22, 2008 at 03:09 PM. Reason: Automerged Doublepost
Ok. I finaly installed my w/b. But when I turn my car to ON, but not to start, my radio reads as follows:
Does anyone know what that means?
once again...anyone know^???
Last edited by TxLonghorn#1; Apr 24, 2008 at 05:09 PM. Reason: Automerged Doublepost
i have no clue i dont knwo how it worked maybe a reverse current something i was useing the lc-1 wideband fron innovative motorsports i dont know how or why it did it but i kid you not it did the engine would die till i pulled the key out even though it was off...... but it stopped doing it after i took the wires off the gauge so i have no clue
n20saturn
Sep 30, 2015 12:26 AM
