WideBand for Interceptor
Old Jul 4, 2007 | 02:10 PM
MacG321's Avatar
What do i need to buy/do to run an accurate air/fuel reading through the interceptor? Thanks for your help.
Old Jul 4, 2007 | 02:19 PM
RedEcotecSS's Avatar
not sure if u can, although i may be wrong.
Old Jul 4, 2007 | 02:22 PM
skymynx's Avatar
i would like to know too free bump
Old Jul 4, 2007 | 02:23 PM
an0malous's Avatar
you can.
ive asked this before but no one really knows where to get the stuff.
basically all we would need from a wideband kit would be the guts...the gauge wouldnt be needed, because we can run an analog input through to our interceptors.
but no one really sells just the guts....so youd have to buy the whole kit anyway.
Old Jul 4, 2007 | 02:24 PM
and when someone buys the whole kit they just use that gauge... i hope someone knows how to do this, i'd like to know also.
Old Jul 4, 2007 | 02:25 PM
skymynx's Avatar
is there a way to run a wire from the wideband to an analog one on the interceptor?
Old Jul 4, 2007 | 03:55 PM
Johnboy12358's Avatar
You can use the innovate wideband that doesnt come with the gauge, I've seen that for sale before... and you can hook it up with the analog 5v wire off the wideband, I've read how to do it before. Let me see if I can find my post on it from forever back....
http://www.aeroforcetech.com/files/I..._version_4.pdf
Page 8, section P. That tells you how to hook up the analog input to a wideband.
Looks like there are different versions of that manual available. I looked at this one:
http://www.aeroforcetech.com/files/I...AL_rev_2_1.pdf
And it looks like the same instructions are on pg 10, section w.
For the wideband, I believe you could use this:
http://www.cobaltperformanceparts.co...roducts_id=160
Old Jul 4, 2007 | 04:04 PM
Acidangel_5.0's Avatar
look at summit.. i know they have what your looking for.. the sell brain boxes seperatly.. i have already talked to them about this and it would be fine.. ill have to look it back up again.. its been a little while
Old Jul 4, 2007 | 04:26 PM
jimbos'ss's Avatar
sweet now all i need is an iterceptor guage and i can run boost and wideband through it.
Old Jul 4, 2007 | 06:12 PM
zinner's Avatar
Moderator Alumni
Innovate LC-1 will work perfectly with the Interceptor.
Old Jul 4, 2007 | 06:30 PM
88cobaltSS's Avatar
How much would the innovative LC-1 cost?
Old Jul 4, 2007 | 06:53 PM
stryder's Avatar
it cost about 200 bucks for the LC-1 cable.
Old Jul 4, 2007 | 06:56 PM
Doc's Avatar
Doc
Thanks Zinner...tons.
$199, here is one or two choices.
DarrenGC
Dec 24, 2021 01:55 PM
nathan112i
Sep 30, 2015 07:12 PM
n20saturn
Sep 30, 2015 12:26 AM
