Wideband Kit
Old May 3, 2006 | 12:46 PM
2K5SS/SC?'s Avatar
Wideband Kit
http://cgi.ebay.com/ebaymotors/Innov...60744023QQrdZ1
Do you guys think this is a good deal? I'm only looking for an A/F gauge that I can place near my tach so I can pay attention to what's going on. The display screen is small enough to do that with this kit. Thanks guys!
Old May 3, 2006 | 01:07 PM
patathSS's Avatar
for what you are doing yes it is prolly enough, I am debating between the LC-1 and the plx250 so I can use my new Interceptor as a display. I know the LC1 works with HPTuners but it requires a seperate bung. The plx250 MAY work with HPTuners but it does not require a seperate bung.
Old May 3, 2006 | 01:36 PM
djt81185's Avatar
plx250 WILL work with hptuners
Old May 3, 2006 | 01:41 PM
Rusty's Avatar
this kit looks like it would be fine. small display, but looks like it has the capability of being logged on a computer with the pc interface. not a bad price either. just remember you'll need to have someone weld in a wideband o2 bung. once u weld that, you can't put it back to stock.
Old May 3, 2006 | 02:47 PM
zinner's Avatar
Moderator Alumni
that looks like a good deal. Lots of tuners like the LC-1 wideband. Putting in another bug isnt' a huge deal. Just take the b pipe to an exhaust shop and they can easily put it in.
Old May 3, 2006 | 02:54 PM
Rusty's Avatar
that part isn't difficult, but i know most cobalt owner will want to eventually revert back to stock. this makes it a little more difficult to do so.
Old May 3, 2006 | 02:57 PM
gforce477's Avatar
AEM Gauge Wideband here, works great, looks great, 2 1/16 size, $269, very popular, works with HP tuners.
Dom
Old May 3, 2006 | 03:58 PM
zinner's Avatar
Moderator Alumni
You can actually buy a plug to fit into the bung to seal it off if you wanna remove the sensor for whatever reason.
If you need a WB O2 you are probably doing some serious tuning and mods and putting it back to stock for whatever reason isn't a compelling reason in my mind. If your worried about putting it back to stock then definetly get the other WB O2 PLX thingy.
Also I think the Innovate WB O2 is more advanced in it's ability to stay calibrated.
For the record I have a Turbo XS tuner lite that I use and I am happy with that. It links into my DTEC FC so I can log AFR with other variables.
Old May 3, 2006 | 05:03 PM
2K5SS/SC?'s Avatar
I wanted it just to see where I'm at with different pulleys, but if I can use it to interface with the HPTuners software, that's even better. I want the small digital gauge because I want to mount it behind the steering wheel on the plactic piece so I can see it while I'm cranking along. My problem is that I'm so focused on the road and RPM gauge that, I never see the boost gauge, so I figured if I mounted it near the tach I'd catch it in my view.
DarrenGC
Dec 24, 2021 01:55 PM
n20saturn
Sep 30, 2015 12:26 AM
Sep 28, 2015 12:51 PM
metroplex
Sep 27, 2015 07:48 AM
