wideband question
If you mean using the stock O2 sensor to run a wideband, then no. I don't think it'll even plug into the wideband box.
just get a bung welded into the downpipe and leave the secondary o2 sensor alone
i dont think it will read it accurately if u use the 2nd o2 sensor bung
are u gonna try or just curious?
Sorry not trying to hijack this thread but do you need to remove the downpipe to put the bung in or is there room to weld it in without removal? Just about to put one in and my buddy says i have to remove it.
your buddy work at a shop?
In order to use your wideband as the primary O2, you'll have to mess with the wideband itself and dick around with the wiring (it varies from wideband to wideband, they should have a guide on their website - Innovate does).
He doesnt but i've got a friend who does. Do you're saying it's dooable with the downpipe left on on a hoist? It just because i know whats gonna happen, i'm going to go and try to take off the down pipe and have to fight with seized in exhaust bolts, probaby breaking one or two off and giving me more grief haha
The sensor should not be pointed down. Heres a install guide from innovate explaining it- http://www.innovatemotorsports.com/s...C-1_Manual.pdf Its on page 7. In order to get it mounted properly you will need to take the dp off.
n20saturn
Sep 30, 2015 12:26 AM
