wideband question
Old May 17, 2010 | 05:52 AM
bbbevans89's Avatar
wideband question
can a wideband run off of the stock o2 sensor without any cells thanks
Old May 17, 2010 | 05:58 AM
06cobalt racer's Avatar
no i heard it doesnt work right. the wideband should have came with one.
Old May 17, 2010 | 10:19 AM
Dainslaif's Avatar
If you mean using the wideband as a narrowband for the car, yes you can do that but it involves splicing some wires.
If you mean using the stock O2 sensor to run a wideband, then no. I don't think it'll even plug into the wideband box.
Old May 17, 2010 | 03:25 PM
bbbevans89's Avatar
i mean can you use the stock o2 sensor hole and make it work so the car doesnt freak out when it doesnt have one lol
Old May 17, 2010 | 03:37 PM
just get a bung welded into the downpipe and leave the secondary o2 sensor alone
i dont think it will read it accurately if u use the 2nd o2 sensor bung
are u gonna try or just curious?
Old May 17, 2010 | 03:40 PM
bbbevans89's Avatar
just wondering lol didnt do anything yet
Old May 17, 2010 | 03:47 PM
yea its cheap to get the bung weld into the downpipe, if u know the shop it will be cheaper than 30 bucks
Old May 17, 2010 | 04:04 PM
Bluelightning's Avatar
Got Bewst?
Sorry not trying to hijack this thread but do you need to remove the downpipe to put the bung in or is there room to weld it in without removal? Just about to put one in and my buddy says i have to remove it.
Old May 17, 2010 | 04:08 PM
CobaltSC06's Avatar
its easier to remove the downpipe
Old May 17, 2010 | 04:17 PM
light'bolt's Avatar
Keep in mind the voltage levels on the wideband sensor are different than the narrowband sensor.
Old May 17, 2010 | 04:18 PM
bbbevans89's Avatar
what does that excatly mean lol
Old May 17, 2010 | 04:22 PM
if u have a lift leave it on haha
your buddy work at a shop?
Old May 17, 2010 | 05:07 PM
Dainslaif's Avatar
You can unplug the thing entirely and drive pretty much like normal. It'll throw codes but it'll drive fine, it just won't use fuel trims.
In order to use your wideband as the primary O2, you'll have to mess with the wideband itself and dick around with the wiring (it varies from wideband to wideband, they should have a guide on their website - Innovate does).
Old May 17, 2010 | 10:18 PM
Got Bewst?
He doesnt but i've got a friend who does. Do you're saying it's dooable with the downpipe left on on a hoist? It just because i know whats gonna happen, i'm going to go and try to take off the down pipe and have to fight with seized in exhaust bolts, probaby breaking one or two off and giving me more grief haha
Old May 18, 2010 | 12:53 AM
haha yea i told to a shop and he lifted the car up and i watched him hit a spot on the downpipe with a small hammer or something haha then he welded the bung in and closed it till i had the wideband later on
Old May 20, 2010 | 01:40 PM
Kennyspec's Avatar
Take the DP off. Im not lying upside down on my back trying to TIG one on for you.
Old May 20, 2010 | 08:59 PM
lift ftw
Old May 20, 2010 | 09:16 PM
skatin_boarding's Avatar
The sensor should not be pointed down. Heres a install guide from innovate explaining it- http://www.innovatemotorsports.com/s...C-1_Manual.pdf Its on page 7. In order to get it mounted properly you will need to take the dp off.
DarrenGC
Dec 24, 2021 01:55 PM
brandon04
Oct 21, 2015 07:04 AM
n20saturn
Sep 30, 2015 12:26 AM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
