The Widest Tire?
Old Oct 6, 2005 | 09:36 AM
memphisr24's Avatar
The Widest Tire?
What do you guys think would be the widest tire you can put on teh stock SS/SC rim? They are 7.5 wide right? Would 225's fit?
Old Oct 6, 2005 | 10:18 AM
BeastlyTA's Avatar
235's will fit for sure. Someone on this board has them and has posted pictures. I dont know if any larger will fit though.
CobaltSS05's Avatar
yes 225's will fit you could even go with a 235 40 18 .
Old Oct 6, 2005 | 05:50 PM
RpSS4844's Avatar
i have 235 40 18 and they fit with no problem. anything wider and it would be a wise decision to go with a wider rim. But there is room for wider.
Old Jan 15, 2006 | 11:26 PM
GotBoost?'s Avatar
I have a question. I want the widest tire you can get on our stock rims, but i want to goa little more lower profile on the side walls. What size would that be? And what would be the best tire to get for overall rain/dry.
Old Jan 15, 2006 | 11:40 PM
JapEatr's Avatar
South Central *********
the stock wheel is 18x7
i have 225/40/18 Bridgestone Potenza RE950s
attn chevy powered
i need pics of your wheels, do you have any probs with the wider wheel?
what size tire? i am lowered and clearence is still pretty decent
with a little slight trimming a 245/45/18 will fit (test fit a set of 350z wheels that ironicly didnt fit the z)
Old Jan 16, 2006 | 10:06 AM
codyss's Avatar
I usually stick with the stock tire size but I see nothing I like in the 215/45/18 size not to mention that due to the rarety of that size they are $$$.
Anyone have pictures of some 225's on the stock rims?
Old Jan 16, 2006 | 10:10 AM
Chevypowered's Avatar
attn chevy powered
Those are my wheels, I have had no problems with the size. I'm going to try to run some 245's in the spring with wheel spacers. I have the stock tires on the for right now. With it lowered it might be some issue since the do stick out quite a bit more than the stock ones do.
Old Jan 16, 2006 | 12:56 PM
shcwv's Avatar
i have the eibach sportlines on my ss/sc, would the 235/40 still fit?
Old Jan 16, 2006 | 09:28 PM
shcwv's Avatar
bump so i can get this question answered^^^
Old Jan 16, 2006 | 09:51 PM
pclear9061's Avatar
i got a set of 225's on my rl and you can feel a difference between 215 and 225 i can just imagine the difference between 215 and 235
Old Jan 16, 2006 | 09:53 PM
p7x's Avatar
p7x
What do u mean by difference exactly? Handling? ride comfort?
Old Jan 16, 2006 | 10:04 PM
shcwv's Avatar
agh! i just want to know if 235/40's will fit on my ss/sc with sportline lowering springs
Old Jan 16, 2006 | 10:44 PM
JapEatr's Avatar
yea
i confirmed it
we got new fuzions in today and i mocked it up out side
Old Jan 16, 2006 | 11:15 PM
shcwv's Avatar
yea
i confirmed it
alright cool, thanks a lot
Old Jan 17, 2006 | 05:36 PM
05YELLOWSS's Avatar
255/50/dr16's
http://www.*************/forums/show...t=drag+radials
Old Jan 17, 2006 | 05:37 PM
05YELLOWSS's Avatar
dammit, it's cobaltss. com if you hadn't figured that out allready, it's my tires...
Old Jun 14, 2006 | 08:56 AM
cybcow's Avatar
What is the widest width that we can fit without rubbing occuring as a daily driver, this is not limited to the factory rims. I see above that supposedly you can fit 240's maybe 245's with trimming on the factory rim, so am I correct in saying that the widest tire would then be 240 or 245 on rather a factory or aftermarket as the widest width?
I haven't seen this made clear in previous posts.
Thanks.
Old Jun 14, 2006 | 11:35 AM
thillerss's Avatar
235/40-18 will fit on factory rims
I have them on my car
Old Jul 11, 2006 | 03:01 AM
fWdCoBaLt's Avatar
The Pirelli P6 FOUR SEASONS 235/40/18 http://www.tirerack.com/tires/tires....peed_rating=ZR
whats everyone think?
Also whats the take on speed ratings? Has or is anyone gone or going below z rated?
Old Jul 11, 2006 | 11:48 PM
SoloSK71's Avatar
Stock wheels are W speed rated. Y rated are pretty common, and a few people have gone to true Z rated.
- Solo
Old Jul 12, 2006 | 12:13 AM
Tomtwtwtw's Avatar
Here's a cheaper tire with much better ratings from the consumer.
Old Jul 12, 2006 | 12:21 AM
fWdCoBaLt's Avatar
what would be better to go with 235/40 or 235/45. hopefully i'll get my car back this week to order these for it
Old Jul 12, 2006 | 01:06 AM
Tomtwtwtw's Avatar
235 will be less than 1% off from stock as far as revolutions per mile. You want to keep that as close as possible...
bigdeertz
Nov 17, 2016 09:41 AM
RaginChopsuey
Oct 27, 2015 01:27 PM
Jimmy Beilfuss
Oct 5, 2015 04:18 AM
DANRICKARD
Oct 1, 2015 12:08 AM
importkiller
Sep 30, 2015 07:18 PM
