Widest tires for the front
Old Feb 13, 2010 | 10:10 PM
XTC_916's Avatar
On the cobalts the back tires will rub first but how wide can you go on the front until it starts to rub?
Old Feb 13, 2010 | 10:50 PM
Frew's Avatar
I believe 245/40, I personally have 225/45/18
Old Feb 13, 2010 | 10:51 PM
XTC_916's Avatar
really damn I wish there was a way to put on some 265's that would be nice.
Old Feb 14, 2010 | 03:40 AM
ralliartist's Avatar
depends on your offset.
with a 38mm offset, you can't go wider than a 26"x9.5" tire.
Old Feb 14, 2010 | 03:49 AM
OneCOLDBIZL272's Avatar
Whats the widest with a 45/18 side wall I'm guessing 235? ???
Old Feb 14, 2010 | 03:15 PM
car_guy_09's Avatar
Im running 245/45's and it rubs my intake on the drivers side when i turn real sharp
Old Feb 14, 2010 | 03:18 PM
ls1fbody's Avatar
Haz l33t wheelz.
245 45??! jeesus, run a 235 40, or 245/35. yu guys are running monster truck tires.
Run the correct aspect ratio and you won't rub.
Old Feb 14, 2010 | 05:02 PM
*boostinss*'s Avatar
i have 235/40/R18 never rubbed yet
Old Feb 14, 2010 | 05:38 PM
im running 225/45/18r and lowered 1 3/4- 2 " and i dont rub, i wonder is 235/45/18r would be and inssue....ummmm
Old Feb 14, 2010 | 05:41 PM
100% METH's Avatar
Don't forget 245/40 on +42 offset
Old Feb 14, 2010 | 06:32 PM
Frew's Avatar
listen, you guys in other states might be able to run smaller sidewalls but I live it pittsburgh, the land of potholes.
Old Feb 14, 2010 | 06:39 PM
selfinfliction's Avatar
235/40/18 is only 0.1" shorter than the oem 215/45/18 and is 0.2" taller than 225/40/18
so 235/40/18 seems to be the best option, i've been running 225/40's for a while now because the tire place here can get a set for me installed for about $350 with a lifetime hazard warranty
Old Feb 14, 2010 | 06:40 PM
shadowfaxss's Avatar
We ran 225/45 Bridgestone 760 sport tires on ASA J8s (18x7.5). They would rub the inner wheel well on a sharp turn and smacking a bump. The 45 aspect is recommended by tire rack on the ss/sc but it is too tall.
This question has been asked before and I believe there is a lot more rubbing going on than what is admitted to.
Old Feb 14, 2010 | 08:56 PM
Maxim_X's Avatar
I put 255/50's on w/ rubbing.
Old Feb 14, 2010 | 08:58 PM
BLAZIN07SS's Avatar
I'm too JDM for you
i had nitto drag radials on the front. 275/45/17 with sportlines. only rubbed while turning and braking
Old Feb 15, 2010 | 12:03 AM
car_guy_09's Avatar
oops i meant 245/40's lol
Old Feb 15, 2010 | 12:05 AM
ls1fbody's Avatar
Haz l33t wheelz.
even so, go down to 245/35
Old Feb 15, 2010 | 06:27 PM
so im lowered now on 225/45/18R's no rub issues. my fenders are rolled now note. what do you think the biggest size tire would fit keeping the 45wall height on a 18 ???/45/18R just curious?
Old Feb 15, 2010 | 07:11 PM
crazywhiteboy89's Avatar
this is on a stock ss sc rim?
Old Feb 15, 2010 | 07:55 PM
Jrhdpaintball's Avatar
ive had 245/45/18 on. they were old tires that were worn down, just did it to test...they rubbed the strut...im lowered on sportlines
Old Feb 15, 2010 | 08:00 PM
ls1fbody's Avatar
Haz l33t wheelz.
why are you so set on a 45 sidewall?
A 235/40 is as close to the stock overall diameter as you can get.
245/35
265/30
etc... they all have a very similar sidewall height.
It's just a percentage of the tread width.
ex: on a 235/40 tire, the tread is 235mm wide, and the sidewall is 40% of that. Technically speaking.
Old Feb 15, 2010 | 10:18 PM
if that was in referance to me... they were not by choice, only because someone was getting rid of them, and simply wanted to see how big the tires could go before it rubbed. 245.45 rubbed slightly...so when i get 245.35's i hopefully would not have any problems
Old Feb 16, 2010 | 06:49 AM
245/35
265/30
I'm just curious I have 225/45/18r now
what's the biggest you can go on 2??/35/18 and 2??/40/18 just would like to know I'm just curious Note 7.5 or 8 wide rim
Old Feb 16, 2010 | 09:38 AM
google tire calcualtors...it will help you alot
Old Feb 16, 2010 | 10:54 AM
Kool kool I'll check that out. Didn't know there was something like that. Thanks
