will a 2.79 pulley work
Old Sep 2, 2007 | 04:00 AM
SSalexSS's Avatar
on stage 2??? wat supporting mods are needed?
Old Sep 2, 2007 | 04:16 AM
Super_SS's Avatar
60lbs injectors,tensinor,tune,and cooling mods
if u plan on goin 2.79 dont even bother goin s2...all ur really need of the s2 kit is the belt...everything else u gotta buy sepratly or u can buy a KIT, from zzp or rebel or Cobalt Addication
Old Sep 2, 2007 | 04:17 AM
ARedWhiner's Avatar
wat he said
Old Sep 2, 2007 | 04:24 AM
Element2.4's Avatar
Many people eun that setup. I would suggest getting a 2.9 but its up to you.
Old Sep 2, 2007 | 04:29 AM
JKennedy1612's Avatar
The lowest you can go is a 2.9. Anything under that, you need at LEAST a tune
Old Sep 2, 2007 | 04:30 AM
Element2.4's Avatar
Many people run 2.8's on the stage 2 tune. It doesnt lean it out to much. It just makes the injectors go static for a split second.
Old Sep 2, 2007 | 04:32 AM
2.8 is too small with stock injectors and tune. At that size you will probably run into heating issues. I've seen guys on the dyno get LOWER numbers due to heat constrictions.
Old Sep 2, 2007 | 04:35 AM
tREBs's Avatar
all depends on altitude as well
theres a few gfuys up here in calgary running 2.8's on stg 2 tunes
Old Sep 2, 2007 | 04:36 AM
Did you notice a difference from your stage 2 pulley to the 2.9?
Old Sep 2, 2007 | 04:40 AM
tREBs's Avatar
actually i did, i gained 2 psi and the but dyno says theres a difference!
What did you dyno?
I just ordered a 2.9 from Nate...I'm anxiously awaiting it in the mail
Last edited by JKennedy1612; Sep 2, 2007 at 04:40 AM. Reason: Automerged Doublepost
Old Sep 2, 2007 | 04:41 AM
tREBs's Avatar
havent been able to dyno yet! all the shops here have a 2 month waiting list.... im hoping around 245-260
Old Sep 2, 2007 | 04:42 AM
Super_SS's Avatar
i gained bout 2.5psi...havent dynoed car before and after,but there is a diffrence after 80mph..car feels more alive and wants u to ram 3rd gear to redline and continue 4th
Old Sep 2, 2007 | 04:43 AM
Sweeet...But before 80 there isn't much of a difference?
Old Sep 2, 2007 | 04:45 AM
tREBs's Avatar
i noticed it pick up between 30-100 and it just wants to keep going!
Old Sep 2, 2007 | 04:46 AM
A lot? Or a slight difference
Old Sep 2, 2007 | 04:47 AM
tREBs's Avatar
well if i were to estimate id say about 15hp?
best damn $50 ive ever spent to say the least!
Old Sep 2, 2007 | 04:54 AM
So your PSI is going up to 17?
Old Sep 2, 2007 | 08:02 AM
braineater's Avatar
i get around 18psi, maybe a bit more. and while i am getting by just fine without any cooling mods they are next on my list anyway.
Old Sep 2, 2007 | 02:05 PM
SSalexSS's Avatar
well i was reading on cobalt addiction and it says the 2.79 pulley will run great on the stage 2 tune and put it in the right afr
this bs?
this bs?
Yeah it is
Old Sep 2, 2007 | 02:09 PM
an0malous's Avatar
I disagree.
show me a car that has popped the motor on S2 and 2.8
yes the IDC are high, and it needs 60lbers.....but after 1-2 years of a large number of people running it, with not 1 single bad result....id say thats pretty decent proof.
is it a garuntee? no
but its very compelling.
Old Sep 2, 2007 | 02:11 PM
ARedWhiner's Avatar
Originally Posted by an0malous
I disagree.
ok well there u go...u said it urself, a safe pulley would be bigger than a 2.8 for a stage 2 tune
an0malous's Avatar
lol
wow your good at reading what you want to hear arent you?
Old Sep 2, 2007 | 02:12 PM
SSalexSS's Avatar
ight so the safest to go with s2 is a 2.9?
