Will DR's Snap axle easily?
Old Oct 31, 2008 | 02:51 PM
CobaltVenomSS's Avatar
well after my tune in january or so with raven i will be done modifying the engine...except maybe some meth in the future....
New mods i will have before tune are CX racing H/E, 60# injectors, BFG KDW II's, and a 2.85 pulley....but i have no traction mods at all cuz i barely go to the track (dad dont like it) so since im getting older he will prolly let me go a little more...so me and bitz thought about buyin a set of DR's to share...but are worried about snapping a axle...
what easy traction mods should i get?
Old Oct 31, 2008 | 02:56 PM
Omega_5's Avatar
Yes... DR's can snap axles easily...
Get solid motor and tranny mounts.... CAB's help a lot too.
Old Oct 31, 2008 | 02:57 PM
thanks...what would u do first? or is it better to do it all at the same time?
Old Oct 31, 2008 | 02:58 PM
ralliartist's Avatar
OMG, wheel hop is the #1 killer of transmissions and axles. Don't wheel hop and your golden.
While slicks/drag radials can break something from the sudden grip of traction, it's just not nearly as likely as wheel hopping.
Old Oct 31, 2008 | 02:59 PM
Omega_5's Avatar
Probably do them all at once if you can. It's gonna set you back a few hundred.
The DR's can still snap an axle if you push enough torque out.
Old Oct 31, 2008 | 03:00 PM
what dr's do u use?
Old Oct 31, 2008 | 03:01 PM
dslouwe's Avatar
I have a complete set of B-woody performance solid motor mounts I'm not using. PM if you might be interested.
Old Oct 31, 2008 | 03:03 PM
PhantomSS's Avatar
DRs were so last year
go plastic or go home
Old Oct 31, 2008 | 03:05 PM
freakta's Avatar
silly question what are cabs
IM WONDERING TOO
Old Oct 31, 2008 | 03:06 PM
arkkornkid's Avatar
found this out the hard way recently, I've had my solid mounts on for so long that when I went to the track for the first time, I wasn't expecting wheel hop and BOOM...driver side axle gone.
Omega_5's Avatar
CAB = Control Arm Bushing
Old Oct 31, 2008 | 04:58 PM
I used Mickey thompson ET street, 26x10.5x16 on my 13.2@104
I'm switching to a hoosier 24.9x8x16 for next season. The mickeys are a great tire, but that was just too big, it made the gearing too long, acceleration suffered. But they are a real wrinkley tire that provides a lot of cushion. I doubt you would break an axle or tranny with them unless you're an idiot.
Old Nov 1, 2008 | 09:49 PM
qwikredline's Avatar
interesting i may go with the nitto dr as hatrickstu did so well with them buddy (dont cry ...) but how about fixing hop with mounts like i do? and you are right driver and slicks make a big difference...control arm bushings dont stop hop i got spherical joints, dont help without mounts..... damn what time is it? past my bedtime
chefhhr
Oct 26, 2015 10:36 PM
biniecki
Oct 25, 2015 02:23 PM
DANRICKARD
Oct 1, 2015 12:08 AM
Tupp
Sep 30, 2015 08:18 PM
