will this throw a CEL?
Old Jul 12, 2008 | 03:17 PM
chochoky86's Avatar
If I put a downpipe with no cat will I get a CEL?
Thanks
Carlos
Old Jul 12, 2008 | 03:19 PM
Bl4des's Avatar
yes you will
Old Jul 12, 2008 | 03:23 PM
chad463's Avatar
sure will, you will have to get someone with hptuners to delete it for you.
Old Jul 12, 2008 | 03:26 PM
NamedGobalt's Avatar
If you look at our car wrong you'll get a CEL. So a downpipe will throw a couple codes probably.
Old Jul 12, 2008 | 04:57 PM
chochoky86's Avatar
Thanks for the info guys I'm gonna do it anyways
Old Jul 12, 2008 | 08:07 PM
Zach06CobaltSC's Avatar
You will have a P0420 code I believe which is because you do not have a cat. If the CEL comes on, which it will about 50miles after you install it, then simply unplug the battery for 5 mins and put it back on. That will clear the code. OR you could just simply buy an interceptor gauge and clear it from inside of your car right away.
Old Jul 13, 2008 | 08:35 PM
chochoky86's Avatar
what's an interceptor gauge?
Old Jul 13, 2008 | 09:23 PM
an interceptor is a gauge, like your boost gauge, that shows you A LOT of different things about your car. I highly recommend you get one. It shows iat1, iat2, which is where i leave mine at, it also scans for codes, clears codes, and shows a lot more, has a shift light, etc. Its pretty cool.
Old Jul 14, 2008 | 02:05 AM
restonSS's Avatar
doesnt it just plug into your obd port or what? where does it get its readings from?
Old Jul 14, 2008 | 02:11 AM
crypticscifer's Avatar
Installation is accomplished by simply plugging the supplied connector into the OBD2 port
below the steering wheel and connecting a separate included wire to a switched 12v
vehicle power source. Virtually plug-and-play!
source: http://www.aeroforcetech.com/Redline_Cobalt_tech.html
Old Jul 14, 2008 | 10:50 AM
AzulitoAlero's Avatar
That does NOT clear a code, just resets all the car's monitors. You still wont pass inspection like that b/c all the monitors will show as not ready until they reset.. and when they do will prob throw the CEL again. Not a permanent answer to your problems.. lol.
Old Jul 14, 2008 | 10:55 AM
silentd's Avatar
yep ull throw codes. enjoy
06MetallicBalt
Jul 20, 2025 08:47 PM
turbochargedss2012
Sep 20, 2023 12:17 PM
DocSvensk
Sep 27, 2015 02:24 PM
jcarroll53
Sep 24, 2015 07:43 PM
ashalle2
Sep 16, 2015 10:36 PM
