Won't boost over 2.5lbs at WOT !!!
Car is a '07 SS/SC w/ Stage 2 and an airbox mod (AEM Dryflow) . I took a good friend and my wife for a ride yesterday WOT up through the gears to 120 a couple times and then came back into town and filled up...Car seemed sluggish after I filled up but I didn't think nothing of it. Well I went to work this morning and the car still felt sluggish so I looked at the boost gauge and no matter what I couldn't get it to boost over 2.5 lbs no matter what gear or RPM. Still drives fine just no power and no boost, can even still kinda hear the SC whine, just no go...What gives ??? Anybody ever experience this ???
you could always try the bypass mod to see if it is the bypass loop or not...
https://www.cobaltss.net/forums/how-guide-43/how-boost-bypass-mod-11994/
but i wouldnt run it like that for a long time if it is, i would take it to the dealer!
Do you feel a misfire or any change in how it cruises, or is the problem only when you go WOT?
dont listen to the guy suggesting the bypass mod. BAD IDEA. this causes boost to build even when the throttle is closed, during low lift operation...BAD IDEA!
check the hoses going to the bypass actuator and make sure that none of them are missing/disconnected. then check for any cracking. if there are no cracks, no missing hoses, then look for leaks.
check your boost gauge line to see if its installed properly.
if none of that works out...dealership.
i gotcha. This deff. has to a problem with the recirculation system...if it was the gauge the car wouldnt be sluggish. And hope to god the PCM isnt causing the bypass actuator to stick...that would be a big issue.
thats true..and its exactly why they build it that way. im just saying that nobody wants a pcm problem, no matter if its detrimental to their engine or not. But chances are that if its stuck for some reason it will be a line, or just a bad valve...a relatively easy fix!
*places $5 bet* on "check your boost gauge line to see if its installed properly. "
n/m...just remembered the stock boost gauge in the Cobalt is electrical. still, check all the boost/vaccum lines going to the bypass from the manifold...
remove the belt and see if the blower spins freely would be my first step, then look for leaks in the induction system. Check the boost bypass, make sure it's not stuck the lines are all solid, stuff like that. If you have a friend rev the engine in neutral you should see the bypass actuate.
Well, i always say, look at what you did before the problem happened. You sayed you filled up right before going home. Sometimes i find myself reaching for the wrong pump because different gas stations put them in different places. the station could have actually fucked up and filled the wrong octane in the actual pump (highly unlikely though). I'd say cyphon the tank if you can and fill up from another gas station with 93 octane, maybe put in some octane booster.
Edit: I get the p0171 from my airbox mod, its nothing to worry about, the other code is definitely showing you whats wrong. Too low an octane will cause your misfire.
From what I can tell all hoses are connected...I pulled the suspected dry rotted hose off and pressure tested by old school method underwater and no leaks, PCV hose is connected. Car starts fine...After connecting the battery and going for a drive it is still the same but the codes are cleared...
There is a sensor that seems like a MAP sensor that is just under the supercharger but mounted on a braket coming off the block. It looks just like a MAP sensor but it is out in the open w/ nothing conected to the underside but it has wires going to it. Is there supposed to be a hose or something connected to the bottom of it or something ??? Anyone know what it is???
Check post #16...
i saw post #16, i'm just saying, root cause. I always fill up on premium as well, but 87 octane will cause misfire or and sluggishness at WOT. I'd say you have nothing to lose if you can't find the problem.
Yep it moves, it's slightly open while at idle and closes (I guess closes) while reving it and when the engine is off...
