WOT box
WOT box
Would i be able to use a WOT box if im running nitrous? I plan on buying a WOT box but nitrous is being added to my build this winter and i dont want to waste money.
What you'd want to do is add a relay to the wire leading to solenoid. Then have the upper clutch position sensor trigger that relay. So if the clutch moves from that sensor, it'll cut power going to the solenoid.
And in simpler terms, the window switch will spray when the gas is to the floor, but because of NLS i hook to the clutch so when the clutch moves, it cuts the spray even though the window switch would still be telling it to spray?
okay im pretty novice when it comes to wiring. Basically buy a relay and connect it to the solenoid, then splice into the clutch position sensor?
N2MB was working on some kind of window switch but I'm not sure I'd trust there window switch over a reputable nitrous companies.
alright now the CPS is the blue and white tube like thing that is connected to a metal bracket around the clutch correct? What color wire do i need to tap for the relay on the CPS? Im just going to do it this way that way i know its right, and not have to worry about one thing doing too much (window switch and 2 step)
okay so i just tap the same wire for the WOT box for the relay, thats no biggie then. How can i test the solenoids without spraying to make sure my wirings right?
Worthless post. Glad to see you can't read.
This cable can drive your nitrous solenoids or water injection pump directly. The output can be programmed to turn on and off at specific RPMs and at a certain throttle threshold. It also automatically shuts off whenever the clutch is down, to prevent spraying during no-lift shifting or launch control. All of the settings can be adjusted using the WOT Box Software.
And he never said he bought a WOTbox, so thats why i posted.
https://www.cobaltss.net/forums/showthread.php?t=198508
Merry Christmas
Merry Christmas
