WOT box help
Old May 13, 2009 | 06:43 PM
greygoose08's Avatar
WOT box help
was looking into getting one. heard it was best for a vheicle without cats. mine has them tho. im barely ever going to use it but is it safe to run the WOT box and not have any issues down the road? Thanks
Old May 13, 2009 | 06:45 PM
Zach06CobaltSC's Avatar
Vince over at trifecta is trying to make a no lift shift option and a rpm launch option for our cobalts. Give him a little bit of time before you dive in on the wot box thing.
Old May 13, 2009 | 06:50 PM
StevesBlack06's Avatar
any rescent update on this??? hows he coming along?
Old May 13, 2009 | 06:54 PM
Last I heard he was doing pretty well. He is thinking about trying to make a knob on the dash that would allow you to change the rpm you could launch at which would be kick ass. I personally wouldn't use the no lift shift option, but a launch option would be kinda nice although I have no problem keeping it at 2k when I launch.
Old May 13, 2009 | 07:03 PM
Maxim_X's Avatar
No you shouldn't have any problems with it. Just don't keep your foot into it to long.
Old May 13, 2009 | 07:18 PM
im still tossing this option around... would this be much harder on the clutch? especially the alreardy crappy stock clutch
Old May 13, 2009 | 07:25 PM
Launching a car is never easy on the clutch but I doubt the wot box would make it any worse.
Old May 13, 2009 | 07:33 PM
InfraRedline's Avatar
I had my cat on for about a month with my WOT box and had no problems, but I dont think thats really enoght time to do damage. If anything it will probably just destroy your cat if your on the 2 step too long
Old May 13, 2009 | 08:14 PM
Maxim_X's Avatar
It's better on the clutch and tranny when your WOT shifting. IDK about launching, I'm sure it's not nice to it.
Old May 13, 2009 | 08:36 PM
well like i said im barely ever going to use it. only when i hit up the track like twice a year. so that 1/4 mile should be fine with my cats and a wot box or not? but yeah id like to have the trifecta thing where its just right in the pcm of the car vs. adding a wot box. but idk thats why im asking peoples opinions.
Old May 13, 2009 | 09:07 PM
If you dont use it all that much you will be just fine
Old May 13, 2009 | 09:52 PM
Area47's Avatar
Rent me! per hour
you have to reflash the box every 2 months, or it freaks for some odd reason. staying on the 2 step to long will cause a p0300 code. wot shifting a lot will kill a cat.
Old May 13, 2009 | 10:46 PM
Maxim_X's Avatar
Mine's been fine for about 6 with no issues. What kind of problems did you see?
Old May 14, 2009 | 01:19 AM
firepinch's Avatar
Wot shifting could ALSO kill a cat??? Ive heard that launch control can kill it but wot shifting... how would this damage a cat in the long term?
Oh and by the way, Clear Image doesn't use a magnaflow cat and they say that it is not made in ceramic inside. Stainless steel I think... would this make a cat more durable with the wot box???
Old May 14, 2009 | 08:48 AM
I think he means wot no lift shifting can kill a cat. I don't know why normal shifting at higher rpm's would kill a cat. I have a high flow cat and I have done a TON of high rpm shifts and my cat is still running correctly.
Old May 14, 2009 | 12:47 PM
firepinch's Avatar
Yeah I think that too and this is exactly what I wanted to say... I should have said "wot no lift shifting"
Sl0wbaltSS
Nov 21, 2018 11:11 PM
ineedacobaltss
Nov 7, 2015 02:25 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
dennis69
Oct 20, 2015 04:49 PM
c_m_shooter
Sep 27, 2015 04:40 PM
