Would a Cobalt Tune work on a Redline?
Old Oct 10, 2006 | 01:18 PM
Smokem10's Avatar
Just what the title says? Thanks...
Old Oct 10, 2006 | 01:24 PM
memphisr24's Avatar
I don't think so. Don't quote me on that though, however I heard our pcm's are a tad bit different.
Old Oct 10, 2006 | 01:28 PM
DWK5150's Avatar
There are some differences so why not just copy them to your tune that you have.
Old Oct 10, 2006 | 01:30 PM
NGalaxyTimmyo's Avatar
I wouldn't do it. At least not a complete copy. There are some things that are the same, but quite a few things are different.
I guess the biggest difference is in the intake, so stuff like that should be left for a cobalt tune. However, I have a fix on my car for the surging idle, and a redline guy did it to his car, and i just copied that.
so to answer the question, yes and no. I wouldn't do it unless you knew what you were doing though. It will work, but I don't think it would be very good for long.
Old Oct 10, 2006 | 01:57 PM
Smokem10's Avatar
My idea was to see if I can buy the the stage #3 retune form CA, and have them email me the tune and either put it on the redline OR just copy the changes over to my tune...actually I was going to ask Spooner from the RL forums and see if he can do the changes over to the redline tune, since he would know what he can change...
I have contacted CA about sending in my PCM for them to tune it, but they have to find a local to see what happens...so it might take some time and they would only charge $229...alot better than $500 for a dyno tune...
Old Oct 10, 2006 | 02:37 PM
DWK5150's Avatar
Dont forget though there is the possibility that there tunes will be locked and if it is you wont be able to see what they change.
Old Oct 10, 2006 | 02:40 PM
Smokem10's Avatar
You are right...they probably are....o'well....
Old Oct 10, 2006 | 02:46 PM
Quicksilver06's Avatar
why dont u try intenses tune. they have the option to pic which vehicle u have. i have there tune for my cobalt and its awesome. also intense does not lock their pcms.
Old Oct 10, 2006 | 02:55 PM
Smokem10's Avatar
did you mail in your PCM? I thought about it, but don't feel like doing the security relearn procedure....did you tell them what you have in your car and they tuned it to that? how is your A/F?
Old Oct 10, 2006 | 02:56 PM
DWK5150's Avatar
Intsense can email you the tune if I recall correctly.
Old Oct 10, 2006 | 02:57 PM
Smokem10's Avatar
well, I will give them a call today.....
Old Oct 10, 2006 | 02:58 PM
DWK5150's Avatar
Give it a shot but dont you already have a tune on your car?
Old Oct 10, 2006 | 03:34 PM
Smokem10's Avatar
Yes, but it is like a prototype tune....I love it though (THANKS SPOONER), but it still needs some fine tuning still to be done....like I get knock in the top end and the surges and bogs...but it is way faster than it was before...
Old Oct 10, 2006 | 05:24 PM
JMAc88's Avatar
My friend and i got our cars tuned at the same time. He has a redline i have a coblat. The guy who tuned it said they were very different to tune each.
Old Oct 10, 2006 | 05:27 PM
Ljavy17's Avatar
Most of tune it will work. the Differences might be the Ve table and certain small things. Of course You have to do your own air fuel ratio since every car is different. but other than that everything works. My tune cosists of a redline and an 06 cobalt. Mines is an 05. I put it all together you just gotta know what you are doing and have some creativity and a scan and wideband gauge. Even though you can use your laptop to check for knock.
Old Oct 10, 2006 | 08:56 PM
automobiliben's Avatar
You have a 2004 RL, you car is MAP based vs. the other year Redline and Cobalts being (I think...) 02 Sensor based. Talk to Sp00ner, he was talking about this the other day. Supposedly, HPT has a feature called compare, where you can compare two tunes and it will identify the differences, and then you can simply make the changes yourself. So, to answer your question, you can, it just isn't a direct transfer.
Old Oct 16, 2006 | 12:50 AM
yea i mail ordered my pcm. i told them what i have done to it. i didnt have do a security relearn cause i sent them my pcm. havent checke a/f but with the tuen it went from an avg. 14.0 car to an avg. 13.7 . best of 13.6 with tune and a slipping clutch. new clutch in my room just saving to put it in
Turbo Johnny
Feb 21, 2019 09:41 AM
BettyBlue2.2
Sep 10, 2015 08:49 PM
shawnsseries
Sep 10, 2015 08:29 PM
DisJuan
Sep 7, 2015 01:51 PM
Getaway_Driver
25
Sep 5, 2015 09:16 PM
