xtc downpipe? cat or no cat???
Old Sep 4, 2007 | 01:52 PM
Altiery54's Avatar
does anyone have the xtc downpipe on their car w/o a cat?
i am trying to decide wether or not to go catless with that downpipe or get the one with the high flow cat
chris
Old Sep 4, 2007 | 01:55 PM
RedlineBrian's Avatar
That is honestly entirely up to you. Do you have somewhere you can get an inspection? What are the consequences if you get caught with out a cat in your state?
Old Sep 4, 2007 | 01:56 PM
Jimmys2007CobaltSS/C's Avatar
in pa...u can do catless and passed emissions as longs as the engine light dont come on..but i didnt kn ow dat otherwise i would had went catless..
is it louder w/o a cat.?..mine car is loud with the cat
Old Sep 4, 2007 | 01:57 PM
Altiery54's Avatar
no i am not worried about the penalties basically what i want to know is it will pry throw a check engine light how easy is it to clear and once it's cleared will it keep re-appearing and whoever has the xtc whether or not they like it
Old Sep 4, 2007 | 01:59 PM
QuikSilverSS's Avatar
go with the high flow cat, that way you dont get any cels, you wont notice a huge difference anyways performace wise, but you sure will sound wise the catless is quite a bit louder. They did a test a while back in one of the sport compact magizines about exhausts with a high flow cat coverter and one without, there was very little difference performance wise like maybe 1-2 hp difference, why put up with the hassle of CEL's and a super loud DP for 1-2 extra HP over a catted DP, just my thoughts others may disagree it just comes down to whats important to you?
Old Sep 4, 2007 | 02:00 PM
i have a high flow cat on my d/p and i got 3 codes popped up i had to get them deleted at the local shop where i had it put on
Old Sep 4, 2007 | 02:04 PM
rickay726's Avatar
catless if you want to be cool
Old Sep 4, 2007 | 02:08 PM
Is the CEL's becuase you are running a 3" DP on the 2.4? Is it to big for your application or is it a Bad cat on your DP? or others? just curious?
Old Sep 4, 2007 | 02:10 PM
joeworkstoohard's Avatar
I do not see any reason to go catless and polute more than you need to.
also, in pennsylvania, it is illegal to remove any factory emissions control.
Old Sep 4, 2007 | 02:20 PM
Altiery54's Avatar
quicksliver how do you like you zzp downpipe with the magnaflow cat??
Old Sep 4, 2007 | 02:41 PM
I liked the downpipe, but my flexpipe actually broke on it so I just removed it, if I were to do it again i probably would have went with the 2.5"dp with cat for that extra bit of torque, the 3" is better in the high rpms but i drive most of the time in the mid rpm range and I think a 2.5" would have been best, however the 3" is a great peice i just have a faultly flexpipe, i am just going to order a new flexpipe and have my exhaust shop weld it back togather, you will notice a drop in boost but no loss in power just more efficient. I lost .5ln of boost from 17.5psi to 16.5psi
Jan 12, 2016 12:01 AM
no_ss
Oct 18, 2015 11:58 PM
nathan112i
Sep 30, 2015 07:12 PM
