ya finally got my ingalls td,
Prothane tranny bushings will also help a lot. Using an ingalls TD or the Turbo Tech Racing Upper Engine Mount with the prothane bushings helps reduce a lot of engine movement and wheel hop.
A self-contained elastomeric shock that mounts on brackets between the engine and the chassis. It reduces extreme engine movement and dampens the motion, providing many benefits. The “Stiffy” was originally intended for the sport compact market, but can be used for some Hot Rod* applications if it is applied correctly.
Benefits:
Greatly improved off-the-line acceleration
Reduced wheel hop
Improved vehicle stability
Reduced shock loads on driveline components
Smoother shifting
Reduced wear on exhaust system joints
Less vibration transmission to the driver compared to polyurethane motor mounts.
Less shock load, compared to torque straps and chains.
Drifting – helps reduce shock loads when wheels gain traction.
Reduces motor movement – decreases the chance of motor parts rubbing against the hood and frame.
