Installed my Weapon R TD
Old Jun 28, 2007 | 09:56 PM
FryLoch's Avatar
It literally took 15 minutes to install!!!
I think I might have it adjusted to tight cause there is alot of vibration...But right now im too lazy to go adjust it today...
I hope it actually works...
any suggestions on adjustments...?
Old Jun 28, 2007 | 10:01 PM
JCswoosher2's Avatar
I sold mine. Didnt like it AT ALL
Old Jun 29, 2007 | 12:17 AM
TurboTechRacing's Avatar
Heard a few complaints of customers who hatted it... At that time they returned it and purchased a Ingalls one.
Old Jun 29, 2007 | 12:53 AM
Timster06SC's Avatar
what is a TD?
Old Jun 29, 2007 | 12:57 AM
Scythe_Snake's Avatar
Originally Posted by Timster06SC
what is a TD?
Torque Damper
Old Jun 29, 2007 | 01:02 AM
jgarciarivera's Avatar
what is a TD?
Ingalls Engineering camber kits - Worlds best Camber kits
The "Stiffy"
A self-contained elastomeric shock that mounts on brackets between the engine and the chassis. It reduces extreme engine movement and dampens the motion, providing many benefits. The “Stiffy” was originally intended for the sport compact market, but can be used for some Hot Rod* applications if it is applied correctly.
Benefits:
Greatly improved off-the-line acceleration
Reduced wheel hop
Improved vehicle stability
Reduced shock loads on driveline components
Smoother shifting
Reduced wear on exhaust system joints
Less vibration transmission to the driver compared to polyurethane motor mounts.
Less shock load, compared to torque straps and chains.
Drifting – helps reduce shock loads when wheels gain traction.
Reduces motor movement – decreases the chance of motor parts rubbing against the hood and frame.
Old Jun 29, 2007 | 01:30 AM
FryLoch's Avatar
I couldn't pass it up, I wanted the ingalls but this was only 70 bucks! cant beat that can you?!?!?
Old Jun 29, 2007 | 07:37 AM
Not for the price, but the quality is aslo not the same as the Ingalls.
Old Jun 29, 2007 | 07:41 AM
Punkloser6's Avatar
yea my friend had weapon r on his tc. kinda trashy compared to the ingalls. i have ingalls on mine. i wouldnt change it for the world. that thing rules. i have ZERO wheel hop. it helps to get rid of those pirelli's too stiff. i ahev proxes 4 on there now. 300 tread life and still Z rated. SO worth it. all the grip and amazing long lasting tread life.
Old Jun 29, 2007 | 07:50 AM
xspyder85x's Avatar
i want to get one soon.
Solaris99
28
Mar 15, 2017 01:22 PM
dennis69
Oct 20, 2015 07:39 AM
justinchinn
Oct 2, 2015 12:18 PM
Delta coupe
Sep 30, 2015 08:11 AM
Bohb
Sep 27, 2015 09:11 PM
