zzp header dp combo problem?
Old Feb 8, 2008 | 04:20 PM
miraclemark's Avatar
i just got my zzp header dp combo put on the check engine light came one i can deal with that( but how do i make it go away?) but i driving it an i get on it the it starts makeing a whistleing / sucking noise has ne 1 had this happen to them is there a bad gasket? help please
Old Feb 8, 2008 | 04:21 PM
Drakonen2000's Avatar
did they put the o2 sensor back in?
Old Feb 8, 2008 | 04:24 PM
yes but not the cat sensor
Old Feb 8, 2008 | 04:26 PM
hungryhip-ccp's Avatar
you can get a cel eliminator
im more worried about the weird whistlen noise
or is it common
Old Feb 8, 2008 | 04:27 PM
well, if you are running a cat, then im guessing that would leave a nice big hole in your exaust where the sensor should be...that would prolly throw a cel and make some kind of racket like you are hearing
Co|3aLt $$'s Avatar
why didn't they put the can sensor in? is it catless or did they just leave that hole open?
edit: I can hear a bit of a "whoooosh" or a sucking noise between the headers and the intake now, but nothing unexpected or crazy..?
Old Feb 8, 2008 | 04:28 PM
exactly...hole open = prolly your noise
the dp doesnt have a cat
well, then, did they tighten all the bolts?
Old Feb 8, 2008 | 04:29 PM
id hope soo i took it to a shop
Old Feb 8, 2008 | 04:30 PM
dosent mean they did!!! ..that would be the first thing i would check if you dont have an open bung....
Old Feb 8, 2008 | 04:33 PM
im gonna go bak over there an let him look at it and ill post bak
Old Feb 8, 2008 | 04:34 PM
good idea, you shouldent be hearing anything like that out of it if it was installd correctly
Old Feb 8, 2008 | 04:36 PM
Co|3aLt $$'s Avatar
what is it 23 lbs ft of tq for those recommended? it doesn't take much to get that... if they can't even do that I wouldn't take it there again... lol. it could also be the gasket between the dp/and the exhaust, the one that came with mine was different that the one that was on the car, i could see how if it wasn't just right it could cause a leak.
Old Feb 9, 2008 | 12:10 AM
shiftingloco310's Avatar
you prolly have a check engine light too from not having a cat.
Old Feb 9, 2008 | 09:24 AM
ok went to the shop and the ******* didnt tighten the bolts from the dp to the header all the way so every thing is fine now i love it it makes a noticeable difference in hp
Old Feb 9, 2008 | 09:36 AM
06blackg85ss's Avatar
well the car is going to sound different without the cat man. could be a leak though btwn the header and the dp flange, pretty common problem. best way to check, with the car idling, hold a piece of paper around that area and see if it's flapping around in any spot. but more then likely it's just you not being used to it.
As for the CEL, it's from the no cat, and o2 removal. You need someone with HPT to turn it off
Sep 27, 2015 08:53 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
ChrisTutoki
Sep 24, 2015 08:39 PM
