zzp header install help
Old Mar 27, 2007 | 06:39 PM
scotts2.0's Avatar
Has anyone installed this header to the stock DP? Can I use the stock studs and bolts or do I need completely new, different bolts and if so what size and type is best?
Old Mar 27, 2007 | 08:11 PM
jflexe99's Avatar
You can probably reuse them...if they are REALLY hard to get off(depending on how long you had your car...) you might have to cut them off...you might just want to get new ones...look at your manual to get the right size...maybe from the factory...or ZZP....just to be on the safe side...up to you.
nathan112i
Sep 30, 2015 07:12 PM
z28addiction
Sep 28, 2015 12:03 AM
Sep 27, 2015 08:53 PM
