ZZP Longtube Headers
I dont think theres any dynos or good videos even of them yet.
Maven said it gave a very nice increase to his 2.2 but thats about the most ive heard so far. But looks like a nice piece!
I'm catless & run the Corsa Touring catback, and have zero rasp. His Corsa catback should sound good no matter which he chooses (high flow cat or catless). It's one of the few catbacks for the SS/SC that actually remove the negative sounds an LSJ can make.
i have the longtubes, felt a nice bump all through the midrange, got very VERY raspy (being that im catless :p ) added a big magnaflow resonator and it removed all the rasp, still loud as **** once u go WOT though, but sounds so sexy!
Everyone that has these should try to get some devent rev/fly by's and some cruising/pulls from the interior
Agreed
I am trying my hardest to make free time between work and school and my personal life to install this header on the stock cat back I promise to get videos for everyone once most of the snow clears up =P. I will also try to get 1 dyno pull with it to show the gains over stock.
I don't think the power gain will be greater than other headers out there but the powerband should be really nice. There is a video on Youtube of someone making 232whp with a LTH and exhaust, other mods are unknown
You won't see a huge difference between different headers. They all improve the powerband for the most part. Some just show more peak power than others, which is basically not important. If you already have a header, just stick with what you have. Its not worth the money to switch.
well the one that i have currently the bolt holes are starting to get bigger? thus causing the bolts to move around and cause a gap... constantly having to re-tighten them. I was interested in the longtube because it's one solid piece...
Damn man, that doesn't sound good at all. Did you torque the studs to spec, in sequence, etc? Either way, that sucks.
