Zzp Lsj Pcm???
Zzp Lsj Pcm???
Okay i heard the intense PCM was a big NO NO.. It runs lean at high rpms resulting in BOOM..
So more research... does anybody know anything about the ZZP LSJ PCM?
thanks for any info
thanks for any info
What mods do you have?
cheers
Well i just purchased the ZZP tune and had it sent via email. I used that tune as a starting point and did some VE and Maf tuning then I tuned the High/low octane tables and it is a strong tune. The original tune was pretty decent by itself.
cheers
cheers
I want a 2.85 pulley on a stage 2 but i don't want the hassle of doing a reflash or anything i basically want to run a straight ZZP pcm. I'll have a full exhaust when i do this.. also a CAI
Last edited by rockkrawler628; Jan 4, 2008 at 12:45 AM. Reason: Automerged Doublepost
Typically canned tunes are not the best but if I had to pick one non gm it would be ZZP. I ran their tune on my GTP and loved it. The only reason I have the GM S2 flash is for warrenty purposes.
places around here are EXPENSIVE!!!
I think im just gonna buy the ZZP LSJ PCM.. put on a 2.9 pulley with the stage 2 **** from gm, some colder plugs, and the full exhaust and hope to god that everything works well and have no check engine lights... otherwise i'll just smash my **** in a tree and the hell with it
Last edited by rockkrawler628; Jan 4, 2008 at 01:32 AM. Reason: Automerged Doublepost
The ZZp is a great starting point to a good tune. Like I said It did need some improvements to MAF and VE. The High octane table has been adjusted but the Low was not. They also did some great stuff to the torque management settings. ect. ect
I would highly recommend it over the stage 2 tune.
Sep 28, 2015 12:51 PM
