ZZP or OTTP
ZZP or OTTP
ok.. so ive made about a million threads trying to do research and getting ideas and blah blah. and i greatly appreciate everyones responses.. thay r positive haha.
anyway.. so im curious to know. i want people with ZZP stage 3 to tell me if they have had ANY problems with it.
and i want the people with OTTP stage 2 to tell me if they had had ANY problems.
Im looking at the 2 and they are basically the exact same thing but the OTTP is close wayyy cheaper. im most likely not getting the pcm from either. but question is, does one come with better parts or something. why is OTTP so much cheaper?
help me guys.. ill be waiting haha
There really are a lot of threads already on this man. Maybe not worded exactly like yours. If I were you I would type in ZZP Stage 3 in the search button, and read all about it. You will not only find what you are looking for, but will actually learn a lot more about the actual kit. Repeat for OTTP Stage 2.
If you still have questions, I'm sure members that have these kits will be able to help you out. Some of the older members like to see that you actually performed some research before giving out answers to your questions. Just giving some friendly advice.
There really are a lot of threads already on this man. Maybe not worded exactly like yours. If I were you I would type in ZZP Stage 3 in the search button, and read all about it. You will not only find what you are looking for, but will actually learn a lot more about the kit. Repeat for OTTP Stage 2.
If you still have questions, I'm sure members on here will be able to help you out. Some of the older members like to see that you actually performed some research before giving out answers to your questions. Just giving some friendly advice.
I like doing my own research on here, and coming up with my own opinion using what I already know about the searched topic. I'll give you a little hint.... the older posts/threads on this site contain some of the best information you will find.
Supporting Vendor
Kits are similarly priced, there are drop down changing options that make the pricing appear different at first.
ZZP ships fast and we've been selling a few stage kits a day recently.
The last thing you want to do is place an order and then have to post this "i ordered an intake from xxx and it took 2 months before i got it. didnt really matter bc my car is garaged in the winter months but still..."
The ZZP belt isn't an OEM GM Belt in the kit, the OTTP one is.
I have a parts from both companies (I started with a ZZP Stage 3 kit). Worked fine, the heat exhanger works good (Stage 3, don't cheap out), if you order OTTP get their heat exchanger too.
Joel
Joel
