zzp pcm HELP PLEASE
zzp pcm HELP PLEASE
Put in the new pcm with my stage two. Wont turn over. No security light. Help please. To my understanding i cant do the relearn without the security light, which isnt going on at all.
I had one break but i thought i fixed it? I also installed fuel injectors, spark plugs, and a smaller pulley all at the same time. Is it safe to drive with an idle issue? And how do i test" fix a vacuum leak (kinda a noob)
it might not be that. id try starting it with the stock pcm first if you have it, but dont drive it on the stock pcm. if its doing the same thing you just gonna search around for a hissing noise and replace that line. idk if it could be injector seals or anything though. any codes?
Haha alright man. Thanks for your help. Trying to get this done tonight. I guess ill just keep going till i figure it out, who knows, by then someone who has had this happen may hop on! Again, thanks!
You know that vacuum hose on top of the intake manifold between the supercharger and fuel injectors ? Check that out and trace it make sure u didn't break it loose somewhere...
Need more info wat did u change?? Did u get a zzp stage kit with injectors..cuz i would think u might have cut one...i did it...i got rid of that crap and put some good old 90 derometer orings in. U should have to lines coming off the bypass valve start there see if u have a cracked hose.
is there a chance you put the bypass valve on backwards? A buddy of mine told me he did that, wasn't pushing any boost, took him forever to figure it out, wouldn't explain the speedometer though
if they didnt disable the "vats" on the pcm lik in hptuners then the car wont turn over either...but idk how they mess with the pcm's at zzp so it may be sumtin totally differnt
