ZZP Shuifter bracket upgrade
Just got the upgraded shifter bracket from ZZP and was wondering if anyone knows how the hell the shifter cables come off? Any help would be appreciated. Thanks
I believe they pry off. When I did mine I remember since they are a little weathered it took some muscle.
There is already a post about these in this section. Search and find that. Good info in there.
Edit: https://www.cobaltss.net/forums/2-0l...racket-239787/
DONT ONLY pry them off. they have quick disconnections on them.. you have to pry with a flat head screwdriver and push back on the plastic cylinder peice(similar to the same way you would on a air compressor quick disconnect).
