07 engine in a 06 car
Old Jun 12, 2012 | 12:26 AM
jdgpuller's Avatar
Now I know the 07 2.2 are different then the 06 meaning the coil packs are different and the 07 has a cam sensor and a 06 doesn't but is that all I want to build. Supercharged engine and use a 07 block are the heads the same or interchange able as far as the o6 clutch and tranny will they still bolt up to a 07 block Should I just stick to the 06 engine all together
Old Jun 12, 2012 | 10:32 AM
07cobaltguy's Avatar
07 crank has a different trigger wheel for the ecu so it wont work unless you swap cranks.
Old Jun 12, 2012 | 11:39 AM
jdgpuller's Avatar
Only reason I want to use a 07 block is cause there stronger
Old Jun 12, 2012 | 12:38 PM
swap everything over into a genII block and it should work.
Old Jun 12, 2012 | 01:44 PM
SS1's Avatar
SS1
i'm running this setup 07 block with 06 head and blower warranty job motor blew , you have to swap the internals ova but it does work and well
vjoel2011
Oct 2, 2015 12:11 PM
Highgross89
20
Sep 11, 2015 03:24 PM
Getaway_Driver
40
Sep 10, 2015 09:11 AM
Adam144
Sep 3, 2015 07:48 PM
