07 LT Turbo Build Thread
Old Jan 4, 2009 | 11:57 PM
PsychoCam's Avatar
Ok so now the build should officially be on its way hopefully very soon. I want to give a big thanks to BIGDAVE b/c I got his complete turbo kit.
I should hopefully be getting it by the end of this week.
The only things I still need to order are boost gauge and boost controller.
I will be doing a custom catback more than likely all 2.5"
Kit includes
intercooler piping (2.25")
cuplers & clamps
Intercooler
Long tube header
Mitsubishi Turbo t25 (external wastgate set at 5 psi)
intake
custom down pipe w/ highflow cat
all vac and oil lines
42 lb injectors w/ harness
hks blow off valve.
Greddy Type RS blow off valve
Turbo Smart Boost Controller
Cobalt Series Boost Gauge
Thanks to DeadZen got my Innovate Motorsports LC1 wideband
Thanks to Mike25 got my Cobalt Series Boost Gauge
And will be Trifecta tuned.
I will keep everyone posted as time goes on. Wanted to start the thread now to spark up any interest or ?'s.
I want to run around 7-9 psi.
Old Jan 4, 2009 | 11:59 PM
hilty003's Avatar
haha good luck buddy. hopefully ill get to see a lil of it in progress.
Old Jan 5, 2009 | 12:00 AM
Preston's Avatar
t25 for the win!
same set up as me
Old Jan 5, 2009 | 12:01 AM
Perfect.disguise's Avatar
You deff won't need 60's with the punny T25 @ 5lbs.
Old Jan 5, 2009 | 12:07 AM
PsychoCam's Avatar
Well I have been looking into 42 lb'ers and my one buddy around the area has stage 2 but never installed it and wants to trade me the 42's for the 60's.
I am more than likely going to work something out with him.
Old Jan 5, 2009 | 12:10 AM
Long tube header? Are you talking about an equal length mani? 42.5lb's will be plenty as I'm sure SS/SC stockers would aswell.
Old Jan 5, 2009 | 12:13 AM
PsychoCam's Avatar
Ya it is a mid length the turbo sits lower down for more air flow. Will get pictures up asap
Old Jan 5, 2009 | 12:18 AM
The engine will put out the same no matter what manifold you have on it. A mid length will give you less exhaust turbulance as it's less restrictive than a log mani and will spool faster (not that the T-25 will have lag). I wonder how much power the Garrett T-25 on a 2.2 will make with 5 lbs, on a GST (4G63T) it makes a little over ~165whp/175ft-lbs on 12psi (Yes, there are other variables besides the boost level, just saying).
Old Jan 5, 2009 | 12:26 AM
PsychoCam's Avatar
some pics are up
Old Jan 5, 2009 | 12:42 AM
Jn2's Avatar
Jn2
looks good, you know where to get water and oil right? get water from the heater hose in the back of the engine, and oil from the block gallery plug, return oil in pan or in dimple, and tee off the return line on the stock resevoir, the one that goes ontop by the valve cover and into the tank, good luck with the kit
Old Jan 5, 2009 | 12:54 AM
hmm..thats not an equal length mani..Looks a cut header with a turbo flange welded to it. How tall is the intercooler?
Old Jan 5, 2009 | 12:59 AM
PsychoCam's Avatar
cant remember the dimensions
Old Jan 5, 2009 | 01:00 AM
Have you test fitted it yet?
Old Jan 5, 2009 | 01:02 AM
PsychoCam's Avatar
I will be definately be needing your knowledge. Do I need to run it into the top of my valve cover where the cap is?
The kit was previously used and all fitted. From BigDave on his 2.2
Old Jan 5, 2009 | 01:16 AM
Sw4y1313's Avatar
My T25 TD04H-19 made 212whp/224wtq on 8psi. He should be fairly close to 200whp on the same boost levels.
Old Jan 5, 2009 | 01:24 AM
I was just trying to shed some insight. Like I mentioned there are other variables like compression ratio and whatnot.
When do you plan on having it running?
Last edited by Perfect.disguise; Jan 5, 2009 at 01:24 AM. Reason: Automerged Doublepost
Old Jan 5, 2009 | 01:27 AM
Sentry's Avatar
Looks good.
Regardless of what anyone else says, I guarantee you those injectors are too big. 42's will be better fit.
I feel like everyone is getting their **** but me! Still got 2 weeks on my order from vulcan.
Old Jan 5, 2009 | 01:29 AM
Sw4y1313's Avatar
Originally Posted by Sentry
Looks good.
Spot on there!
Hey if you need to get rid of those 60's, ill be happy to take them off your hands since im looking for a set right now. hehe. Ill definitely need them too
Old Jan 5, 2009 | 01:33 AM
Like I said above even a set of stock SS/SC injectors would probably be fine.
Old Jan 5, 2009 | 10:51 PM
PsychoCam's Avatar
Update on the process. I recieved the tracking number and the whole kit should be here in a couple days as fedex told me.
I am more than likely ordering my boost gauge and boost controller tonight
Old Jan 6, 2009 | 07:55 PM
o3nisoaso3's Avatar
well i have stockers if you want to do a deal for the 42s lol n ill be helping with his install. and hell if everyone is saying if youre lookin at most 200whp then you can get away with stock injectors til you go with the motor build n higher boost
Old Jan 6, 2009 | 08:02 PM
PsychoCam's Avatar
Kit should be here tmrw than have to wait for a good weekend to install and tune
Old Jan 6, 2009 | 09:13 PM
o3nisoaso3's Avatar
i got the next two weeks free
Old Jan 6, 2009 | 09:28 PM
PsychoCam's Avatar
I am thinking in about a month. Since I go to school this monday I will need to do random things like get everything ready and prepared for install. Do you have any idea where I can get a te04h turbo gasket for the flange to header
Old Jan 6, 2009 | 09:40 PM
Jn2's Avatar
Jn2
eBay !!!!! Search td05 gasket
