08 Cobalt LS burning coolant
My cobalt has started to burn coolant (approx. 2L in 2 months). I can't see any leaks anywhere, I checked the rad hoses and clamps and they're fine, and there is never a puddle under the car regardless of how long I leave the car.
I'm stumped. Last night was the first time the fan stayed on after I shut the car off, and I only drove the car less than 5km. The temp light hasn't come on at all. Any ideas? I have an appointment at the dealer to get them to run the dye through it to see what they can find.
Pull your dipstick and see if the oil looks milky. Also look under your oil cap. Unfortunately if you don't see any leaks anywhere it sounds like you may have a headgasket on it's way out.
Oh, and nice to see another local on the forum. Pretty sure I've seen you on lowmo.
Burning coolant? lmao..Listen if you had a blown HG, you'd know it. You'd have white smoking pouring out that the tail pipe. You want to know for sure? Buy the kit that you mix with your coolant and if it turns a certain color you will know if theres a combustion leak or not. It sounds to me u have a leak somewhere and you can't find it and your starting to go crazy about a Headgasket. If you don't know, take it to a shop.
