10 Months in waiting...
Old May 21, 2009 | 01:54 AM
  #51
elecblue06's Avatar
Originally Posted by NWAE Cobalt
you got it!!!
and ill have my tires here soon enough to regain top...but way more then14.8 lol
and tell him ill race him off the track anyday for cash
14.5 isn't way more the 14.8 lol
and with a tune.. he might still be faster.. his car weighs 2200 lbs lol
Old May 21, 2009 | 01:56 AM
  #52
NWAE Cobalt's Avatar
he drives a cavi then and its not a fair race
so he wont be against me on the list anyway
Old May 21, 2009 | 01:58 AM
  #53
elecblue06's Avatar
nope he drives an ion sedan ... io told you .. he has weight reduction lol
Old May 21, 2009 | 02:02 AM
  #54
he has no interior....AT ALL lol
again, he will be in the non cobalt top ten....so dont care
Last edited by NWAE Cobalt; May 21, 2009 at 02:02 AM. Reason: Automerged Doublepost
  #55
elecblue06's Avatar
haha that i dunno
i'll find out this weekend lol
Old May 22, 2009 | 12:21 PM
  #56
o3nisoaso3's Avatar
yes well, he doesnt count
and why not!?!?
VIDS TONIGHT........
Old May 22, 2009 | 12:42 PM
  #57
elecblue06's Avatar
w00t
Old May 22, 2009 | 01:18 PM
  #58
Originally Posted by o3nisoaso3
and why not!?!?
vids...POST VIDS!!!!
Old May 23, 2009 | 01:24 PM
  #59
o3nisoaso3's Avatar
i had to go find a smaller belt, mine wasnt the right size for the UDP and no a/c its running now, gonna do a little tuning then will get vids. it may have a vacuum leak somewhere cause i dont got an idle
Old May 23, 2009 | 04:54 PM
  #60
check your brake booster hose, we opted to replace that dumb ass fitting with a hose clamp as the other one kept moving and leaking
Old May 23, 2009 | 07:17 PM
  #61
o3nisoaso3's Avatar
i did a smoke test, didnt leak anywhere from throttle body on to motor and vacuum lines. car runs like ass, has no pull. maybe internals are already broke or some ****? idk bout to put a stock motor back in the damn thing n call it a day
Old May 23, 2009 | 07:18 PM
  #62
seriously??? as in put the stocker in and your done done???
Old May 23, 2009 | 07:21 PM
  #63
o3nisoaso3's Avatar
as in go to junkyard get a motor, put it in with the full bolt ons, have a tune and call it at that. maybe go get another car n build that. mikes friend is sellin a 93 si hatch with no motor..... Boosted K20?
Old May 23, 2009 | 07:24 PM
  #64
wow
if you do go that route let me know what you have sitting around from this build..
I hope you dont have to though...
Last edited by NWAE Cobalt; May 23, 2009 at 07:24 PM. Reason: Automerged Doublepost
Old May 24, 2009 | 12:26 AM
  #65
o3nisoaso3's Avatar
idk man. retuned it after some data logging and it still wouldnt do dick with the idle. im not thinkin internals got fucked up somehow? (car was never outta time and everything was installed to exact spec)
Old May 24, 2009 | 12:30 AM
  #66
06_ion2's Avatar
well what is it exactly doing?
Old May 24, 2009 | 01:34 AM
  #67
MP Cobalt's Avatar
Plan and simple. Falling on it's Face, cant think of a better way to say it.
Old May 24, 2009 | 02:27 AM
  #68
06_ion2's Avatar
well is it from spark? fuel? tb? done any tests on them?
Old May 24, 2009 | 06:23 AM
  #69
alanoo's Avatar
You know, knock can very VERY quickly kill your internals, even with only 1 severe knock event.
Stock ignition advance map + raised CR = boom
Old May 24, 2009 | 10:20 AM
  #70
MP Cobalt's Avatar
We went through everything, might have bent a valve again but very slightly. Or possibly balance shafts are creating some problem, but I don't have a clue what they could cause.
Old May 24, 2009 | 12:30 PM
  #71
o3nisoaso3's Avatar
well it will start then jumpy idle and stall
fuel is my main concern at this point, think it may be old but i did vacuum smoke test and spark plug test, both good. t/b is clapping which is what lead to vacuum leak test but it was brand new from dealer so it shouldnt be bad. soon to do compression and leak down tests
yes i know that, right now i am not much advanced on timing and compression ratio is 10.2-10.3 so im not worried about too that at this point, balance shafts are 90% the problem with causing knock sensor to go off (in my mind) but its not going off much. and the gas may be a problem too.
i have disconnected the knock sensor (left it plugged in) and motor still wouldnt idle. next on list is drain fuel and get new fuel filter. if that dont help, probably pull motor and put a stock in for now then fix this one before i swap it back in.
im just so fed up wit this damn car right now im bout to quit on it
Old May 24, 2009 | 09:04 PM
  #72
06_ion2's Avatar
try turning around your MAF it might be backwards man. i did this after putting on my FMIC and it kept idling horrable and killed itself alot.
Old May 24, 2009 | 10:58 PM
  #73
o3nisoaso3's Avatar
the maf isnt in backwards. checked it
Old May 25, 2009 | 12:04 AM
  #74
06_ion2's Avatar
try another maf then? it has to be the maf or the map. hmm
Old May 25, 2009 | 05:50 AM
  #75
alanoo's Avatar
bad spark plug gap ?
TB not opening enough at idle (bad cal) ?
Are you using a constant fuel pressure in US or a vaccum operated variable one like us in europe ? (with vaccum coming from the manifold)
