14s easily obtainable?
Old Nov 6, 2006 | 04:10 AM
  #51
NJHK's Avatar
Originally Posted by superSS/SC
But it's not the SS/SC's governor like he said, because the SS/SC's only have a fuel cut at around 158.
Gotcha
Old Nov 6, 2006 | 07:52 PM
  #52
IonNinja's Avatar
Originally Posted by 07BlackCobalt-LS
Haha these Spec V's are in a way faster class then our cars from a dig. Almost 1 1/2 seconds faster stock to stock. Best way to race them is 60 Punch on the highway. They will pull midway through third but soon as I hit 4th I can even it up and finally pull ahead by about a half car around 120 - 130. With my 500 - 700 dollars worth of mods I can Make my 12k car hang with a 19k car. Once my ordered parts get here and I tune it I shoudl be pulling them mean.
que? that would make a Spec V like a mid 14 second car. at best stock they are a low 15 second car.
do you mean you pass them once they hit the brakes? if u got your ass kicked from 60-115 you pretty much lost
Old Nov 6, 2006 | 07:54 PM
  #53
8cd03gro's Avatar
spec v's can hit mid 14's stock.... and i dont see how it is possible to start pulling that hard in fourth unless he hits his governer or runs out of gear
Old Nov 6, 2006 | 08:07 PM
  #54
IonNinja's Avatar
are you talking SENTRA Spec V or Altima Spec V cuz theres no way in hell a car with 2.4 power (Sentra) is getting mid 14's stock
and if you truly do mean 1 1/2 seconds faster in the 1/4 you definitely are talking about the Altima SE-R so nevermind, even then a raised governor is not gonna help you!
Old Nov 6, 2006 | 09:09 PM
  #55
8cd03gro's Avatar
i actually didnt even read the thread....LOL. im kinda bored.
Old Nov 7, 2006 | 10:12 PM
  #56
FLCobalt's Avatar
ive seen Ls run like 15.5 with those mods. 14.9 seems like a stretch
Old Nov 7, 2006 | 10:25 PM
  #57
sethallen's Avatar
i don't think 14's are attainabe for the 2.2 w/o FI
it's barely attainable (if at all) with the 2.4's w/o FI also
Old Nov 7, 2006 | 11:21 PM
  #58
IonNinja's Avatar
you can hit it without FI, u just need to cut a little weight and have a great suspension setup for the track + sticky rubber
Old Nov 9, 2006 | 06:49 PM
  #59
sethallen's Avatar
has anyone done it yet?
Old Nov 9, 2006 | 07:00 PM
  #60
Brandon97Z's Avatar
The key word here is easily. Without n2o not its not. 2.4's are having a hard enough time as it is.
Old Nov 9, 2006 | 07:10 PM
  #61
g5mike's Avatar
well along with the cams and tune,Im having a port and polish done tommorro, so I would go out on a limb and say if the track was still open up here I might have a good shot at 14s
Old Nov 9, 2006 | 07:56 PM
  #62
IonNinja's Avatar
not in a Cobalt/Ion
Old Nov 9, 2006 | 10:20 PM
  #63
06Pursuit's Avatar
IMO I think that even with just CAI, header back exhaust a stiffy and some poly mounts thats its possible to pull 15.00 14.90
Old Nov 9, 2006 | 10:24 PM
  #64
8cd03gro's Avatar
not on stock rubber or imo anything less than dr's. you have to realize how much of a jump high 15's to high 14's is. it is the difference between most suv's and say an rsx-s, my car, or something along the same straight line performance range. it is a very big change in performance. hey, it could happen i guess, but in my opinion it is not going to.
Old Nov 10, 2006 | 01:32 AM
  #65
nomoreavril's Avatar
lol, well i'd just be happy with 14.99
Old Nov 10, 2006 | 08:06 AM
  #66
07BlackCobalt-LS's Avatar
Ohh I dont know. Im at 15.100 now. I can almost guarantee you that once my new CAI installed and the HPTuners tune gets done just right ill be hitting 14.9's once I get a set of Nitto Neogens so I can hook up better.
Old Nov 10, 2006 | 08:37 AM
  #67
8cd03gro's Avatar
your sig says you have ported and polished head....that will do alot.
Old Nov 10, 2006 | 12:02 PM
  #68
what exactly is a port and polish? and where did you get it done + cost?
Old Nov 10, 2006 | 01:18 PM
  #69
PayJ's Avatar
porting is increasing the size of any hole usually for larger pistons..but you can port throttle bodies, intake manifolds, exaust manifolds, and im sure others but those are the most common
Old Nov 10, 2006 | 01:39 PM
  #70
Brandon97Z's Avatar
P&P on a head usually involves cleaning up and wideing up the exhaust and intake ports, smoothing them out and cleaning everything up. I'm sure someone else could give a little more detail.
Old Nov 10, 2006 | 02:22 PM
  #71
slowion2's Avatar
you're thinking of overbore of the cylinders, not port work, which increases displacement
you don't need to hog these ports out much at all, just clean them up, and they'll flow well with a good cam grind.
lol at the posts in this thread
Old Nov 10, 2006 | 04:34 PM
  #72
8cd03gro's Avatar
in lamemans terms...port+polish= greater flowing heads. more air getting in+more getting out= more power. alot more than most bolt ons will do.
Old Nov 10, 2006 | 05:21 PM
  #73
g5mike's Avatar
thanks for your post,since Im a dumb as, you just explained it for me since my cams,valves and other **** is being done they are cleaning up my head as we speak
Old Nov 14, 2006 | 11:45 PM
  #74
Red07SSNA's Avatar
At the risk of sounding like a know-it-all-jackass (I've done all of this before). Porting and polishing your cylinder head's intake and exhaust ports is really nothing more than cosmetic on a street engine turning 6500 RPM -- our cylinder heads have nice open passagesways that provide all the flow you'll need. That said, there's nothing wrong with P+P if you already have your cylinder head off for other reasons -- it just doesn't make sense to go through the expense only to P+P. There are other things to consider as well: valve pocket clean-up, this is where you grind away material behind the valve to remove minor obstructions, sharp edges, and turns. A good machine shop can "open up" the valve pocket by cutting the valve opening within .040" of the valve seat, then put in a three or five angle valve seat cut. You could go a step further and increase the size of the valves (if the combustion chamber can handle it). When increasing the size of the valve you also have to take into account how close the valve is to the cylinder wall -- if the valve opens and there is no room between the valve and the cylinder wall the flow is seriously obstructed. Port matching is also a serious help -- if you've taken off your 2.2 exhaust manifold it is not port matched. On mine the #1 and #4 ports were off by up to 15% (look at the residue on the exhaust manifold to understand what I'm referring to. The GMPP manifold was a lot better but could still use a little finessing. Use a new gasket to port match the exhaust (header or manifold). First check the mating of the gasket to the cylinder head ports and open grind the ports to just meet the opening of the gasket then align the header/manifold to the cylinder head mark the gasket position to the header/manifold then grind the ports of the header/manifold to the gasket. OOps -- long enough....
Old Nov 15, 2006 | 12:00 AM
  #75
g5mike's Avatar
funny the timing of your writeup,you are exactly right,since the damage is done im going the route you have explained, stepping up one size for the valves and going with the copper gluides,these ecotec if you bend the valves good chance you screwed the guides as well,no i dont expect any gains but I had to have it done anyways, no thanks to my buddy trying to do my cams. and no you dont sound like a know-it-all I for one apprciate the fact that you have taken the time to elaborate for me,once again thanks dude
