2.2 Auto Tranny Problems
Old Sep 14, 2006 | 12:52 AM
SSinPhilly's Avatar
Ok guys....this question is from a 03 Cavalier I have and i thought you guys could help me out. Im not sure if the tranny is bad or it could be electrical but here are the problems:
1. Shifts through all Gears in 1-2-3-D (no matter what i put it in it's like its overdrive)
2. Will only go in overdrive Somthing like if i mash it getting on the highway it will go into OD other times it will get stuck in 3rd.
Could it be a sensor?
I'm sorry if listing this problem is againts .net rules. Thanks for your help guys!
Old Sep 14, 2006 | 01:24 AM
SSinPhilly's Avatar
anything.......im trying to sell this car so i need to figure. Anyone know any possibilities?
Old Sep 14, 2006 | 02:02 PM
SSinPhilly's Avatar
Does anybody have anything at all?????
Old Sep 14, 2006 | 02:03 PM
D4u2s0t's Avatar
i don't understand the problem... what do you mean by it shifts though all gears?? isn't that what it's supposed to do? a little better description will get you better answers...
Old Sep 14, 2006 | 07:13 PM
YSUsteven's Avatar
had a friend, her car all of a sudden did not want to shift out of second, got it checked, she was low on tranny fluid. Check yours, maybe you'll get lucky.
Old Sep 14, 2006 | 07:16 PM
05BlackCobaltSS's Avatar
I am confused by the question....
Old Sep 14, 2006 | 07:20 PM
YSUsteven's Avatar
Is the car warm when you get on the highway?
Had a 98 saturn, did not shift into 4 one day, took it to dealer and found out that it would not shift to 4th until the engine was at operating temp.
Old Sep 14, 2006 | 07:22 PM
mkulrey13's Avatar
umm i think hes trying to say every gear is acting like over drive? and to get it in OD you have to step on it hard? were in the dark here
Old Sep 14, 2006 | 07:25 PM
YSUsteven's Avatar
1. When he puts the car in LOW gear it will continue to shift to second, third and somethimes 4th. How could you not understand what he said?
2. Sometimes when its in D, it will not shift into 4th gear.
Old Sep 14, 2006 | 08:18 PM
D4u2s0t's Avatar
you didn't finish the quote... don't knock people and only post half the issue.. he also said that every gear is like overdrive... what does that mean? if it shifts though the gears, then it's not like overdrive, is it
Old Sep 14, 2006 | 08:29 PM
SSinPhilly's Avatar
Exactly i dont understand what you don't get.....
When the shifter is in 1st gear i will still shift through the gears making it overdrive. The same with second and third. It will not go in a low gear and stay in it.
Old Sep 14, 2006 | 08:30 PM
SSinPhilly's Avatar
and yes i have have to step on it hard to almost bang it into OD. TEMP has nothing to do with it.
Old Sep 14, 2006 | 08:37 PM
D4u2s0t's Avatar
well, low will switch to 2nd and i think 2nd will switch to 3rd... anything other than that take it in immediately...
Old Sep 14, 2006 | 09:20 PM
SSinPhilly's Avatar
its not under warranty......i just thought someone would have an idea of what it is
Old Sep 15, 2006 | 07:11 PM
YSUsteven's Avatar
did you check you tranny fluid level?
Old Sep 16, 2006 | 12:40 AM
D4u2s0t's Avatar
why no warrenty? did you pass your miles already?
Old Sep 16, 2006 | 02:45 AM
SSinPhilly's Avatar
no its a salvage.... it only has 36k
Old Sep 16, 2006 | 02:46 AM
SSinPhilly's Avatar
im selling the car i just wanted to see if i could fix the problem..
2003 Ls Sport Sedan 36k for $4k
Old Sep 16, 2006 | 11:55 AM
YSUsteven's Avatar
Well, did you???
Old Sep 16, 2006 | 12:25 PM
Switt23's Avatar
I believe in the 2003's there is a sensor that prohibits the transmission to stay in low gear if it's approaching the red line. Basically Chevy didn't want a bunch of stupid kids trying to do burnouts by putting the car in low gear and holding it there. So the computer tells the transmission to shift into a higher gear, so you don't blow it up.
I remember a post about something like that on J-Body.org. Have you asked the cavy guys there? The site is full of amazingly smart people.
Old Sep 16, 2006 | 02:52 PM
NJHK's Avatar
Well, from a sellers point of view, if you find someone to buy the car, more than likely their going to test drive it in "D" and not try to shift it manually. If they try to come back to you down the line, just tell them "It worked fine with me". Not trying to be mean to others or anything but it's not like you're giving them a car with a busted motor, if the car drives fine in "D", it's an automatic, they shouldn't be really putting it in other gears or even trying to race it by shifting it themselves.
Conclusion - Car drives fine in D, sell it, don't feel guilty.
Old Sep 16, 2006 | 03:47 PM
SSinPhilly's Avatar
i guess i could do that
Old Sep 16, 2006 | 09:48 PM
NJHK's Avatar
It's not as deceatful as you think. Good lukc
OrangeCoba
Oct 1, 2015 10:00 PM
MrInsanityWolf
Sep 29, 2015 04:54 PM
Iceberg
Sep 29, 2015 12:33 PM
Iceberg
Sep 28, 2015 01:31 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
