2.2 Injectors
Old Oct 16, 2007 | 12:51 AM
HunterKiller89's Avatar
2.2 Injectors
what are the 2.2 stock injectors rated? 24lb? 28lb? im gonna be running my 42lbers soon and need to know how much fuel to cut out.
Old Oct 16, 2007 | 01:13 AM
Admiral Jedi's Avatar
24lb I believe.
Old Oct 16, 2007 | 01:19 AM
thought so. so i need to remove 43% fuel from the 42lb injectors to run like stock 24lb injectors....sounds good i spose.
does anyone know if i am supposed to enter the -57 value in all the MAP Load AND MAF Load cells? or just the MAP Load cells? cause i think if you do both, it will try and reduce fuel flow by 114%, but im not positive.
Old Oct 16, 2007 | 09:10 AM
Sw4y1313's Avatar
neg, hold on ill post something for ya.
EDIT: (copied from one of my previous posts)
The calculations for larger injectors:
The 2.2 has a stock injector size of 24lb/hr. That makes it a 252cc injector. If i want to run larger injectors on my car it would come out to:
(32lb/hr)252/336 - 1 = -25%
(42.5lb/hr)252/446.25 - 1 = -43.52%
(60lb/hr)252/630 - 1 = -60%
Ok, so what you need to do is put -43.52 in the fuel map in EVERY cell. Yeah i know thats a lot. Ill reinstall the software tonight and clarify it with you. Ill also have that diagram for ya. Might be late because my engine is here =P
Old Oct 16, 2007 | 07:32 PM
already got that done
since the FIC isnt actually installed in the car yet, ive only done some basic things. Ive rescaled it to a 7000RPM redline instead of an 8500RPM redline to get more usable cells, along with scaling it for 30PSIa boost, as i doubt ill be above 15PSI ever. i might not even go above 10PSI since ive got a 3.4" pulley
all the cells are showing -43% (my calculations gave me -42.8 or something that rounds up to 43?) and thats about everything i can do at this point
DarrenGC
Dec 24, 2021 01:55 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
patooyee
Oct 15, 2015 05:11 PM
yellow dragon
Sep 28, 2015 09:49 PM
