2.2 ?'s
2.2 ?'s
OK I have a 2006 cobalt Lt automatic I have a AEM cold air intake and complete 3.5 inch apexi exhaust I was wonderin what other mods I can do that won't cost me an arm and a leg. Is there actually a tune for the automatic and what is this shift kit I keep hearing people talk about.
You can lower the car, strust bat and sway bar, a shift kit.. B&M or Autotrans Interceptor(harder to find since they dont make em anymore)
a shift kit increases line preasure in your tranny and helps you shift quicker.. it dosnt make it any faster just gets rid of the lagg between gears.. also makes you chirp into 2nd lol
also .. you can go w/ a lil throttle in a bottle lol
Is your exhaust 3.5 inch or just the tip? 3.5 inches is way too big for the pipe sizing.
The tune will be coming for automatics soon from ClearImage, check the group buy section of clear image.
Once you get all of the intake and exhaust parts done you can start on suspension or looks.
The strut bar is a nice start. Sway bar group buy is also going on through Turbo Tech Racing.
http://www.youtube.com/watch?v=aOQh5Z07YS0
thats my car with a shift kit.. listen to the chirp
you can check out ebay or on here search the forums for B&M Shift Plus.. i have an Auto Trans Interceptor.. easier install just plugs in but they no longer make them but check ebay for that too
2.4 intake manifold upgrade kit from Crate engine Depot....ZZP header...
For the 2.2, an 2.25 inches exhaust like the GMPP is good enough...
Last edited by MasterMike; Apr 13, 2008 at 09:32 PM. Reason: Automerged Doublepost
You are losing a lot of torque down low with an exhaust that big. But the top end would be great.
Hell finish it off with the ZZP header and downpipe combo. 3 inch all the way. Loud as hell and power to spare.
Your going to have horsepower up the wazzu but your torque will be lacking with an exhaust that size....until your cranking enough out to warrant an exhaust that size....like they said Crate Engine Depot's 2.4L Intake Swap, body modifications for suspension. Maybe a grounding kit for your speaker clarity,
because too big of an ecxhaust causes you to loose back pressuer on the engin wich causes HP loss..
cams and tune that bitch
https://www.cobaltss.net/forums/supporting-vendor-deals-group-purchases-133/2-2-beta-test-96709/
